Question about Samsung Refrigerators
Samsung rb215lash freezer not working...ice build up ...so I melted the ice but before I did that I checked the heating element and the defrost thermostat both are fine checked them with my ohm meter so I plugged it in and same thing after a few week's so I de-iced it again checked the heater element and defrost thermostat both are fine what else can I check so my freezer can work properly Model # rb215lash/xaa Serial # 197341aq600334 w
Posted by 08r1_rf on
  • 08r1_rf
    08r1_rf Jun 27, 2020
    Honestly I think I didnt but I'll check that and let you know if its good ...if it's good what else can I check..thank you so much for the response
Andrew Taylor
    Top Expert:
  • Samsung Master
  • 32,974 Answers
In mine it was the defrost timer. It defrosts once every 24 hours.
There is a thermal fuse on the defrost heater, did you check that?
https://www.repairclinic.com/ProductDetail/1420821
Posted on Jun 26, 2020
5 Related Answers
Anonymous
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
Anonymous
  • 64 Answers
SOURCE: Need photo of Defrost Switch or Sensor
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Posted on Jul 02, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Posted on Sep 04, 2009
william bennett
  • 945 Answers
SOURCE: Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Posted on Oct 24, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: the cooling coils are icing
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Posted on Aug 07, 2010
Whirlpool fridge gets frost build up in freezer
This means you have a defrost problem or a bad door gasket.
Apr 24, 2016 | Whirlpool Refrigerators
Samsung Refrigerator Model RB215LASH Fan motor in freezer becoming increasingly loud
Your problem here is a build up of ice in the freezer.
If you manually defrost the fridge and the problem disappears then you have found the solution.
The defrost cycle is faulty and you will need a technician to sort it out for you
Mar 30, 2011 | Samsung RB215LASH
Freezer drain may be blocked. Freezer not working effeciently the freezer always icing up
. If the freezer is always icing up , you probably have the problem in your defroster circuit . The refrigerator cycles once every six to eight hours into the defrost mode . This is controlled by the defrost timer. when in this mode , a heating element located close to the evaporator heats up and melts the ice. This heating element will heat up any ice enough to melt It and drain out of the unit. I would check this first .
Feb 19, 2011 | Maytag MZD2766GES Side by Side...
Ice build up around fan in frezeer.makes looud noise....if not melted the refridgrator part a bottom of unit stops cooling.....if melted fan runs smthly....things cool well, but happens again over noght...
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Aug 23, 2010 | Kenmore 64802 Top Freezer Refrigerator
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
FRIDGE AND FREEZER QUIT COOLING
Aug 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leaking kenmore side byside Refridgerator . It seems to leakout the freezer door side. Ice builds up at the bottom or floor of the freezer.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model when ice is gone take back cover off find drain hole and clean
Aug 14, 2009 | Refrigerators
My ED5HHAXVQ02 refrigerator is not cooling. However the freezer is overfreezing and frost is building up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
No cooling in refridgerator
is freezer cooling?
a possible cause is build up of ice on the evaporator. take off the back panel in the freezer and check. also check the fan is working. if there is excessive ice build up, this can mean that the defrost system is not working. in any case, if there is ice build-up, carefully melt the ice off with a hairdryer
Jun 19, 2008 | Samsung RB215LASH
Refrigerators Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
