Question about Refrigerators
I have a fridgetair FFU14F5HWF freezer and fan does not stop running and freezer is only 25 deg. Will not freeze ice I replaced the defrost thermostat any other ideas
Posted by Christopher Anzaldi on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 56,001 Answers
How about checking refrigerant?
Posted on Jul 13, 2020
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Freezer defrosts too long.
Outside of HVACRH20 excellent advice, here a few stats about this model. The main control board will monitor the resistance of the evaporator thermistor. This is located near the top of the evaporator. This thermistor determines when the unit goes into and out of defrost. The bi-metal is redundant to the operation. It will terminate the defrost only if the thermistor fails. Check the values of the thermistor with the attached chart. Catriver..post back
Posted on Jan 28, 2007
22yooper
James Helmer
  • 828 Answers
SOURCE: Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Posted on Jul 09, 2008
robboatoz
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
tom weber
  • 198 Answers
SOURCE: GE PROFILE FREEZER FAN STAYS OFF TOO LONG..ITEMS DEFROSTING
The fan stops during the whole defrost cycle, there is a bi metal control that determines the length of time the heater stays on. This could be the problem, if the heater stays on for the time that is allowed by the defrost timer it will get too warm in the freezer. the bi metal is located on the evaporator.
Posted on Feb 28, 2009
FRT211NLHWO FREEZER 22 DEG FRIDG 50 DEG
Lets begin by placing defrost timer into forced defrost. The defrost timer is inside the fresh food compartment and behind the control panel above the top shelf. Click Here=> 215846602 Defrost Timer
sea_breeze_274.jpg Try turning the timer clockwise slowly until you hear compressor and fans stop. Allow to remain here for 30 minutes. The timer if good should come out of defrost itself but if not it is a clear indication that the timer be replaced. You also should hear a crackling or sizzle coming from the freezer with door open. Also water should drain down to a condenstate tray below refrigerator into a tray that compressor fan warms to return back into air inside your home. If not timer causing the ice blocking airflow then we have the defrost heater and defrost thermostat to examine. They are located behind the rear panel inside freezer The=> 5317842502 Defrost Heater
And also the Defrost Thermostat=> 216872200 Defrost Thermostat
sea_breeze_276.jpg Testing the defrost heater can be found here=> 5317842502 defrost Heater Testing
I have laid these parts out as the timer being the most likely reason for warm temps in fresh food and freezer. If you have any questions I will be here to answer them for you, If helpful please rate, Thank You, Sea Breeze
Oct 30, 2011 | Refrigerators
Freezer temp flux's, items thaw and ice melts. I replaced the defrost heater and the thermostat. Now the freezed cools to 16 deg and now it is up to 29 deg. What should I look at next?
The defrost circuit is made up of the defrost heater, defrost thermostat and the timer. If the timer is keeping it on for too long then it could duplicate your symptoms.
BUT also make sure that the condenser grill (underneath your unit) is clean and air flow is good from front to back of the unit.
Jul 20, 2011 | Microwave Ovens
Ice maker just stopped making ice. had no problem up to a complete stop
Hi and welcome to FixYa, I am Kelly
First off make sure the water in door still works. If it does not work suspect the door / light switch.
Next make sure the freezer temp is below 16 Deg F. The ice maker has a thermostat that starts the ice harvest / fill cycle and if the freezer is warming up because of automatic defrosting problems (Ice build up on the evaporator coils) the ice maker will never cycle. If you note an ice build up in the back of the freezer compartment or poor air flow from the evaporator fan you have an automatic defrosting problem. If the fan is not running at full speed the bearings or windings on the evaporator fan are failing and there is not enough air flow to get the freezer to @ or Below 16 F.
Check to make sure the evaporator fan in the freezer and the condenser fan in the rear bottom of the unit are running un-obstructed. (clean as necessary.... but if the front of the cabinet is hot to the touch then the condenser coils my be clogged with lint or... the condenser fan is not running full speed.
The ice maker may be cycling but it may not be filling with water. If it is cycling but your not getting any water.... at all the prime suspect is the solenoid on the inlet water valve. The water valve is not repairable.
Make sure that the rubber fill tube on the back of ice maker is not blocked with ice... squeeze the end of the tube. If it is frozen with ice... the inlet water valve is bypassing water off cycle and causing the tube to freeze up. The only remedy for this is to replace the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Kelly
Apr 16, 2011 | Kenmore Refrigerators
Roper RT18DKXHN00 High Temperature
No I don't think so. I think you either have a stopped up defrost drain or a bad defrost heater and terminator. Get into the evaporation section and check for ice. If the defrost heater is bad replace the defrost terminator thermostat. Would not be a bad idea to replace the timer or adc (auto defrost control). The fins are coils on the compressor should be clean and the fan motor(if applicable) by the compressor should be running when the compressor is.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 16, 2010 | Roper RT16DKXK Top Freezer Refrigerator
Food is freezing on left side of refrig and not so cold on right
Check the back wall of the freezer section for any ice buildup. This would be from a failure to defrost and requires parts.
Check the freezer side for the evaporator fan motor. Is the fan motor running?
If not a fan motor is needed.
If there is ice on the back wall of the freezer you can activate the defrost control by turning the cold control thermostat OFF then back ON "3" times.
Once you activate the control listen closely in the freezer side for a sizzling sound. This would indicate the defrost thermostat and defrost heater are good and the defrost timer needs replacing. If there is no sizzling sound after 20 minutes,the defrost thermostat and possibly the defrost heater need replacing.
Nov 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer coils regularly freeze over
You have an automatic defrost problem. Here are the three components that can cause this defect in order of most common to least. #1 defrost timer or equivalent adaptive defrost control board, #2 defrost termination thermostat (should be replaced regardless since it has been frozen in ice several times) #3 defrost heating element(rarely fails but is possible). If you have a meter you can check the thermostat and element for continuity they should show an infinite reading if they are operational. the termination thermostat must be below 35 deg f to show a closed circuit.
Apr 02, 2009 | Refrigerators
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
