Question about Dell Computers & Internet
How To Connect Dell e514dw Wireless Setup? - Dell Computers & Internet
Posted by sophie smith on
  • 1 more comment
  • Larry Ng
    Larry Ng Jun 26, 2020
    how to use a Dell e514dw PRINTER.
    but...
    NO PC told no OS told windows MAC?
    what router,? or what Access POINT wifi?
    do you have wifi credentials at hand?
    did you lose the free manual ?
    do you know your home wifi credentials.>
    SSID name = JohnDoe123 (any)
    encryption allows = WPA2 +
    pass phrase?= Ur*7%[email protected] (example)
    I guess using the USB cable is no fun?
    not needing wifi to it
    the manuals, are free and at dell, 24/7
    https://www.dell.com/support/home/en-us/...
    setup guide, 36 pages that?
    page 5 connect, usb cable.
    load Dell software for the printer
    done.
    ,ok now wire less. always more hard. for sure not testing home wifi first say with a cell phone, proving it works and you know your credentials.
    page 7 wifi, remove the USB cable FIRST.
    load the Dell software from dell.com
    then run the say wifi setup
    that is the easy guide and many folks fail here.
    so use the full manual guide.
    Dell Multifunction Printer E514dw User's Guide
    page 28 and more, there are 2 ways to setup wireless. WPS way if your router does that
    or use manual way at the LDC at the printer.
    page 28 covers this.
    https://downloads.dell.com/manuals/all-p...
    the his PDF covers all ways to do it.
    get the PDF keep it for next time too.
    your printer face has a wifi button, see that?
    this printer has 3 ways to connect
    USB
    WIFI
    ethernet wired.
    page 198 on cover wifi connections all ways possible dell, nor me know what wifi you have at home, heck even if you are at home, not a business setup.
    this printer seems 5 years old, (as hold as)
    and the manual shows WPS connections
    that are not allowed now on modern routers or modern AP (access points) it is not a banned feature.. so if you router is new and no WPS button, do not not read those WPS pages in the manual, or go batty.
  • Larry Ng
    that was long answer short of not pasting all that here.
    the short answer is read the manual
    or tell what router you have (and PC & OS or if MAC)
    and tell if you know your wifi credentials.
    even till (omg) do you own that router wifi or is owned and locked down by the ISP.
    if is is their router only they know the wifi
    credentials (locked) call them ask.
    or look on back of router see sticker from ISP there stated , credentials just for your home.
  • Anonymous Jun 30, 2020
    or use USB connection not wifi
    then on unstated PC set up a share to your printer.
    hint #2 some Printer must be reset to switch from connection modes.
    wifi/ethernet wired,or usb.
    this is covered in the manual how to.
    if you just found a printer, used
    reset it first. per the manual.
    this always works if the printer is still good.
    2015 is oldest one I think.
    also the rules. (1 example)
    install the dell printer driver package first
    not last.
    then plug in the USB cable to printer #2
    bingo, that easy.
    wifi is more tricky for sure NOT KNOWING your WIFI credentials going in.
Simon Kamau
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Start by pressing the menu button, select System, select Admin Menu, select Network, Select Wireless Setup, select your network from the list, then enter your network passphrase. Print a Settings Report to confirm the printer has successfully joined your wireless network.
Posted on Jun 26, 2020
How i setup for wireless
Hi
If you go here:
Product Support Dell US
you can click on the "PDF" link next to Manuals, and the manual will be downloaded to your browser. It can then be saved to your computer for future reference.
Pages 30 to 35 give displays all the settings for wireless operation, you need to enter the correct settings for your wireless network and the printer should work.
You may find it easier to connect the printer via USB and then use the setup CD to setup wireless for the printer which will then allow you to disconnect USB & start using wireless. This is on pages 92 & following.
Dec 16, 2014 | Dell 3110cn Laser Printer
I'm trying to install a wireless router for my laptop using the High speed internet land line connection. The D-Link DIR-601 displays a message that say's 'Router Setup cannot run over a wireless...
The router is clear (Router Setup cannot run over a wireless connection) NEVER try to setup the wireless settings trough the wireless connection on ANNY router (I'm impressed it is a verry intelligent router) a lot of routers will permit wireless setup trough wireless but obviously this one wont
Connect a CAT5 patch cable from one of the router's ethernet ports to your computer, than setup your wireless connection...
Have fun
Dec 31, 2010 | Computers & Internet
My Dell lattitude D830 won't connect with linksys
Right-click the wireless icon with red X and click on View Available wireless networks. Highlight the name of your wireless network and click Connect. If it asks you for the network key, type in the secuirty key of the router and press connect. That should do it. If you don't know the wireless security key of the router, you can see it by accessing the router's Setup Page through http://192.168.1.1 on your browser. It's under wireless tab then wireless security sub tab
Sep 23, 2009 | Linksys WRT300N Wireless Router
I have installed my WBR-1310 wireless G Router, but can not get my Dell inspiron labtop to connect to the internet.
Have you connected to the WBR-1310with an ethernet cable and typed http://192.168.1.1 in your browser to setup the wireless SSID? If so, does your Dell show a wireless network available and is the Dell wireless card turned on?
Jul 06, 2009 | Computers & Internet
Dell inspiron 3800 laptop SSID ?
SSID: Service Set Identifier
It is the name of the Wireless connection,
Seems ur trying to connect to internet using WIFI and not a cable.
Then in this case u need to set up ur wireless connection
Check this link to connect to wireless
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
May 30, 2009 | Dell Inspiron 1501 Notebook
Trying to setup 4500s i had fixed
Use the Wireless setup in Control Panel to configure your wireless connection. Setup your wireless configuration with the disc you received with your Router/Modem. Call your Inet vendor for help.
Apr 12, 2009 | Dell Dimension 4500 PC Desktop
US Robotics Wireless Router problem
Sounds like some settings on the wireless router might be setup wrong...like DNS. While hooked into wireless, try going to a command prompt and type ipconfig /renew. Once it refreshes, type in ipconfig /flushdns. Try the Internet.
If that doesn't work then check the settings on the wireless router and see if the DHCP is setup with a static IP or dynamic one.
Depending on what that says, I can provide next steps.
Apr 11, 2009 | Dell Computers & Internet
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Wireless network problem
What operating system do you have running on the Dell? Is there a hardware/software firewall setup/installed?
Nov 25, 2007 | Dell Inspiron XPS M140 Notebook
Open Questions:
Computers & Internet Logo
24 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
