Question about OKI Office Equipment & Supplies
OKI C822 is showing an error 461 every time I start printing but it disappears after maybe 30 seconds and then prints automatically.
Paper dimensions and stock are the same as in the settings and I get the error for a few years now so turining it on and off do not help.
Posted by Alex Krajco on
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: OKI 5600 - Can you do a 'clean'?
Clean Cyan led head (on lid)
Replace Cyan drum with new
Posted on Dec 20, 2007
Buschchris1
Chris Busch
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
Anonymous
SOURCE: oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
Posted on Mar 30, 2009
Anonymous
  • 7 Answers
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Posted on May 30, 2009
Anonymous
  • 6 Answers
SOURCE: Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Posted on Jun 27, 2009
OKI 461 error C531dn LED Colour printer.Says the paper is wrong but it isn't! It's suggesting I have to load A5 paper although I am printing A4 and it's an A4 tray. Done loads of printing before.
I suspect you have sent the job to the MP ray and it wants you to put paper in it. Cancel the job and go back into the driver and make sure paper source is set to the cassette.
Aug 17, 2017 | OKI Office Equipment & Supplies
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49 http://www.manualslib.com/manual/113847/Oki-B4545-Mfp.html
Apr 25, 2016 | OKI Office Equipment & Supplies
231 service call error 03
https://www.youtube.com/watch?v=5C2KAer0818
Mar 14, 2016 | Oki Printing Solutions C511DN LED Printer...
Printer stops printing, blinks
maybe have a look in the settings and change the priority setting to right now or urgent or something like that
Mar 28, 2012 | Okidata 591 Printer
Print error on print report and am using win 7 and usb virtual port 1 What is the connection problem as the demo prtout on the printer works ok
Main causse of printer failer is printing interruption and corrupted files for driver.
Solution 1. Check for the device manager to see some error in hardwares especially the usb port. If there is reinstall the missing driver because maybe it is corrupted.
Solution 2. Most printer error can be resolve by uninstalling and reinstalling the printer software.
Solution 3. Maybe the is confusion on the buffer and he does not recognized the printing files. Try no to print usual character that will make printer to confuse. To solve this:
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your pr
Dec 24, 2010 | OKI C3200n Led Printer
Have an OKI Printing Solution C5800 color printer received the following error message: Check Toner cartridge 543K Toner Sensor error - have already changed the Drum and the toner. The error will not go...
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Aug 08, 2008 | OKI Office Equipment & Supplies
Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Apr 08, 2008 | OKI C5500n Printer
OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Jan 02, 2008 | OKI C5200n Laser Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
59 people viewed this question
Top OKI Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
