Televison & Video Logo
Jose Guzman Posted on Jun 25, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED A S03 BOARD - Televison & Video
Amos McRee
Level 2:
Habit-Forming:
  • Expert 82 Answers
  • Posted on Jun 25, 2020
Amos McRee
Expert
Level 2:
Habit-Forming:
Answers
82
Questions
0
Helped
8112
Points
282
Model number and part ame helps alot if its a tv part ebay or shopimmy
How can I fix Riso HC5500 error code S03-201?
  • Code: S03
  • Description:
  • Belt platen lock
  • Causes:
  • The belt platen elevation mechanism cannot be set properly.
    200 S03 Transfer belt motor timeout The motor shaft encoder of the transfer belt motor does not attain the specified pulse count within the specified time. The required movement does not complete even when the transfer belt motor operates for the specified interval. 201 S03 Transfer belt unit sensor error The three sensors that determine the position of the belt platen produced an abnormal detection result. 231 S03 Belt platen operation error The upper limit position sensor fails to activate when the belt platen rises. 240 S03 Belt platen operation error The upper limit position sensor fails to deactivate when the belt platen lowers. 241 S03 Belt platen operation error The lower limit position sensor fails to activate when the belt platen lowers. 242 S03 Belt platen operation error The lower limit position sensor fails to deactivate when the belt platen rises. 243 S03 Belt platen operation error The vacuum positioning sensor fails to activate when the belt platen operates. 244 S03 Belt platen operation error The vacuum positioning sensor fails to deactivate when the belt platen operates.
  • Remedy:<>Reset power, or execute [Clear error] in Test mode. <>Some errors (such as PCB disconnection) may not be cleared by executing [Clear error]. <>Even if an S error occurs, it may be possible to continue operations using another unit. Therefore, certain error types require a specific reset procedure (described in Error Point).
Take it in for service, or replace all the sensors if you can find them for sale.
https://www.google.com/search?q=Riso+HC5500+error+code+S03-201
2helpful
I have a Furuno 1721 MARK- 2 , Type RDP-098 with a RSB-0067 Scanner. What signal cable do I need and where could I find one. I would need a 15 to 20 meters in length.. Thanks
Sorry Dave. The links that Ngoro has provided CLEARLY state that the cable is no longer available from Furuno in the U.S. or Canada.
His two additional comments come up 404.
You MIGHT get lucky on Ebay or Craigslist.
Sorry I couldn't have been of more assistance to you.
-Steve
Product Detail 008 428 590
1helpful
Erreur riso comcolor 7050 s03-2011
The belt platen elevation wires are loose ... detection switch activated.
The sustain peadal in my yamaha s03 is unable . How do i fix this problem?
Press Utility and scroll (up/down arrows) till you see FSTxCtlNo and press inc/yes until it says 64. Your sustain will now work. Hit exit to get out of edit mode.
Jan 14, 2012 • Music
My piano keyboard yamaha s03 sustain is unable. How do i fix this ?
In simple English
2helpful
Tefal steam cooker type S03 request user guide ofr operation
Hi there.
You can visit http://www.tefal.co.uk for steamer Owner's Manual download.
regards.
Riso 7050r error code S03-2011
This indicates that the belt platen elevation wires are loose, or the detection switch has gone faulty.
This part is not easy to access and repairing it will need significant technical know-how, unfortunately.
Toshibo tivo error code S03
...from the Tivo community:
http://www.tivocommunity.com/tivo-vb/archive/index.php/t-285853.html
Probably a processor code that means "general purpose interrupt"..means that your 'box is unstable' and/or the system
chip or related is very sensitive to outside noise. The Tivo people
are correct..just GET A NEW ONE.
WW [email protected]
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
