Question about Garden
What 2 stroke oil to fuel mixture to use for dy 36 chainsaw?
Posted by Bryan Dennis on
Karen Marie Wright
All 2 strokes take a 50:1 mix. Thats 2.6 ounces of 2 stroke oil, to 1 clean unleaded gallon of gasoline.
Posted on Jun 25, 2020
What fuel does stihl MS 192 T take, 2 or 4 stroke?
these small engines take 2 stroke oil/gas mixture, usually a 50 : 1 ratio, a little heaver on the oil is better than too light. the oil in the gas lubes the internal parts of the engine. if straight gas is introduced into gas tank just remove & replace with 2 stroke mixture. if engine has not been operated with straight gas, no harm will be done.
Apr 26, 2014 | Garden
Proper fuel mixture for Dynamac DY 51?
you would be safe to run a standard 25:1 mix 200ml of 2-stoke oil to 5 liters of petrol/fuel/gas.....(5000ml divided by 200ml= 25) most 2 stoke oil is able to run at 50: 1 mix ...instuctions on what oil ratio should be used are always displayed on the oil bottle you buy for aircooled 2 stroke engines....
Dec 03, 2013 | Garden
Fuel/oil mixture ratio huskvarna 350
With Husqvarna two stroke oil it should run at 50-1, with other two stroke oil run it at 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
Nov 25, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Fuel mixture for a Husqyarna E-series 137, mod/137802010
The mixture should be 50-1 with Husqvarna rwo stroke oil, it is recommended that you use a mixture of 25-1 with other brands of two stroke oil, this is because they do not know the quaility of other brands, always try to find genuine Husqvarna oil.
Aug 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Fuel to oil mix for jonsered 490 chainsaw ?
its a 50 - 1 mix of 2 stroke oil to fuel or 2 1/2 ounces of oil to 1 gallon of gas
Apr 03, 2011 | Garden
Fuel and two stroke mix pls oil type for chain pls
For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  • Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Mar 20, 2011 | Oregon Cutting Systems Chain Saw Cutting...
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
