Question about Garden
I can’t get my sthil bg86c blower to rev up properly, obviously I have changed filters, plug and cleaned everything including gas filter now I’m stumped
Posted by Fred Mitchell on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garden Master
  • 35,775 Answers
Try cleaning the exhaust screen
Posted on Jun 24, 2020
Vernon Taylor
  • Garden Master
  • 6,659 Answers
It could be a weak spark but most likely it is not receiving the fuel it needs for full throttle operation.
Assuming the fuel is fresh and there isn't an excess of oil this can be tested to some degree by opening the throttle fully and then partially applying the cold start if it can be applied separately or partially covering the intake of the carb with a finger if it can't.
If this improves things it proves the mixture is too lean and it could be a blockage or a matter of adjustment.
One thought occurs - if it was ok before being idle over winter, it is possible the crankshaft oil seals have lost flexibility and air is being drawn past them into the crankcase.
  • Fred Mitchell Jun 24, 2020
    Is there any other filters for the fuel
Engine wont rev up
the fuel system is blocked up
perhaps the plug is bad
and the air filter will need replaced
or the fuel tank vent is also blocked up
Nov 28, 2013 | Stihl Br 500 550 600 Backpack Blower...
Bg86c spark plug change
the tool you got with the unit for changing other parts
usually is a T shape and has two hex socket at the top of the T and the stem has a torx 10 or similar on it
is also used to change the spark plug
Nov 16, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl bg86c blower. Quit running after abt twenty mins of good strong blowing. Didn't sputter or anything, just dead quit. Not getting fuel to cylinder. Checked filter,gas lines, took apart cleaned and put...
take it in for a carby rebuild
the rest is perfectly fine
if you have been using e-mix fuels , don't as it damages the delicate diaphragms in the carby
Jul 08, 2017 | Garden
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Sthil fs 45c, no power, exhaust filter clean, new spark plug, new gas
If the spark arrestor has been cleaned then it could well be the muffler itself, or the exhaust port blocked, remove the muffler and check the port for carbon build up.
Jul 08, 2012 | Garden
Only runs on choke, will not rev-up. took exaust off did not change, fuel is filter clean, plug has been cleaned, new fuel and let idle till it got hot, still will not rev-up
Your description sounds like fuel restriction in the main circuit. Sometimes you need to soak the carb in carb cleaner and then blow out passageways with compressed air.
There is one "cheat" but it involves some higher throttle, and that is you remove the air filter, rev up the unit and briefly place palm over the intake. Sometimes this is enough to pull the obstruction free.
Nov 06, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Sep 21, 2009 | Echo Garden
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
