Question about Ultrex Crock Pots & Slow Cookers
I need a free printable manual for my ultrex pressure cooker #021201. Where can I get one at? Thank You
Posted by Sharon Massengale on
Tom Chichester
    Top Expert:
  • Ultrex Master
  • 60,292 Answers
Contact Ultrex directly to inquire.
Posted on Nov 11, 2020
3 Related Answers
Anonymous
  • 5 Answers
SOURCE: ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Posted on Feb 21, 2009
Anonymous
SOURCE: ultrex pressure cooker manual
where do i get a tower pressure cooker manual from?
Posted on Nov 01, 2009
Ronald Thompson
  • 560 Answers
SOURCE: I need control cord for ultrex electric pressure cooker
Check with an appliance parts stroe or on the internet.
Posted on Jan 12, 2015
I have an electric ultrex pressure cooker. What temperature should I set it to cook a 4.25 pounds corned beef
It goes by minutes under steam pressure. You likely will need about 1 hours in the pressure cooker to make it tender.
Mar 16, 2017 | Ultrex Crock Pots & Slow Cookers
Jan 12, 2015 | Ultrex Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    I need an instruction manual for a ultrex020800 pressure cooker
    http://www.manualsonline.com/ex/product/headline/m/ultrex/d/Pressure%2BCooker/p/020800
    Sep 24, 2012 | Crock Pots & Slow Cookers
    The recalled 8 qt ultrex ll pressure cooker model # 11302c will the lid come off on its own or does it just not lock while under pressure?
    Halt, do not use this pressure cook. The lid is suspose to lock. This means the lid become a dangerous fly object if it came off under pressure, plus extremely hot boiling water and the contents of the pressure cooker. Beside possible dying from the lid, and if one survives the flying lid, one will be will scalded by the contents of the pressure cooker. Another pressure cooker manufactured in China. Sorry, GB...stewbison
    Sep 12, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
    Bought a new Ultrex II 6-quart non-stick pressure cooker
    I found numerous recipes on 'About.com' Type in the receipe that you are wanting and add pressure cooker to the search. I have also found recipes on other search engines.
    Dec 19, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex pressure cooker manual
    Apr 21, 2008 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    55 people viewed this question
    Top Ultrex Crock Pots & Slow Cookers Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you an Ultrex Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
