Question about Garden
Black and Decker model 7451 type 1 trigger - looks like they are no longer made anywhere in the free world - any alternative switch or am I going to have to hard wire it and control it by plugging/unplugging it?
Posted by Jeff Shipman on
Andrew Taylor
    Top Expert:
  • Garden Master
  • 33,433 Answers
Trigger available on this one stripped down for parts
https://www.ebay.com/itm/Black-Decker-Belt-Sander-7451-TYPE-2-Parts-Sold-Individually-Or-As-Part-Group-/183926335324#viTabs_0
Trigger & Power Cord : The trigger worked well and there should be ample wire left to tie it into your motor. The cord itself has a lot of damage and tape repairs, but I let it be so that the collar and other parts can be used.
Or the other thing you could do is bypass the switch, fill the hole with epoxy putty and put a sliding light switch in the cord near the sander tail.
https://www.amazon.ca/uxcell%C2%AE-Inline-Switch-Toggle-Table/dp/B07P5YW8TG
Posted on Jun 24, 2020
5 Related Answers
Anonymous
  • 97 Answers
SOURCE: plastic safety key broke Black & Decker table saw cat# 1736
Try sears .They shoul be able to get it eor you
Posted on Mar 14, 2009
Anonymous
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need charging instructions for black & decker
Hello. Use an ordinary extension cord and plug it into the back of the light and into the wall. Charge it for 20-30 hours, but not more than 30 hours. Here is the downloadable manual for future reference
http://demandware.edgesuite.net/aaea_prd/on/demandware.static/Sites-black-and-decker-Site/Sites-cpo-master-catalog/default/v1269899899597/dw_manuals/black-and-decker/bdknvec157bd/bdknvec157bd_manual.pdf
Posted on Mar 29, 2010
Anonymous
SOURCE: Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Posted on Mar 31, 2010
Anonymous
SOURCE: mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Posted on Jul 22, 2010
Black & Decker Cordless Pole SawNPP2018 Chain
hi
no much that we can help you now
it look's like you need a new motor and trigger switch
or may be more cheaper to buy a new one try a different make or model this time
Oct 24, 2013 | Black & Decker Garden
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I have a Sears Craftsman 71/4 " circular saw, model number is; 31510864 which is no longer supported by Sears. My trigger (on/off) switch has gone bad and am looking for the part number and hope...
I don't know if this will help you but I have found in the past that craftsman and black & decker small power tools used the same switches. Hope this helps you. Thanks
May 17, 2011 | Garden
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
Black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
Sep 08, 2009 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
How do I replace battery in Black and Decker cordless screwdriver
Just to clarify you have a model number 9076 and I would assume type 1. If so there are screws holding the 2 halves together that would have to be removed the batterys are in the lower section of tool. They are about 8.60. I would recommend going to DeWaltservicenet.com and typing in your model number to look at a product explosion before attempting this repair. Keep in mind that I saw that quite a few of the parts are no longer available so it might be time to retire this one.
Jan 01, 2009 | Black & Decker 9072CTN 2.4V Cordless...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
