The SH (not 5 H) error indicates that the freezer sensor is shorted in the display. The control can't determine what the freezer temperature currently is. You need to check the wiring between the thermistor (temperature sensor/resistor) and the control board. Replace the thermistor if the wiring has no damage. If the wiring is faulty, replace that. If the fault returns, you may have a problem with the control board.
Please add a comment with the model number of the side-by-side refrigerator if you need a parts diagram. I hope this helps.
Hello Andeo Deonarayan - Typically SB indicates that the unit is in Sabbath Mode. It is a feature that disables portions of the refrigerator and it is controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community. Sabbath Mode is turn ON and OFF by pressing and holding the down arrow on freezer temp and up arrow on refrigerator temper for five seconds.
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
