Have ? thorn 65inch smart 4k TV. When i select input on remote control and select smart tv to access apps the Android logo stays there and loops. Is there anyway to do a hard reset. I have looked for a reset button cant find one also disconnected tv and held the power and V- down button down still cant reset. Any help is appreciated
Posted by John Perring on
  • John Perring
    John Perring Jun 26, 2020
    Andorid logo just loops when you you select input then select smart tv.
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 34,193 Answers
How do I reset my Smart TV Android?
How to hard reset your Android TV
  1. Unplug the power cord.
  2. Press and hold the reset button on the bottom of the device.
  3. While holding the button, plug the power cord back in and continue holding the button until you see "Google" on your TV.
Feb 5, 2015
How to factory reset Android TV - Mobile Geeks
www.mobilegeeks.com > factory-reset-android-tv
Search for:
Posted on Jun 24, 2020
  • 4 more comments
  • John Perring
    I don't have a reset button on tv
  • Andrew Taylor
    Andrew Taylor Jun 26, 2020
    The On Off button.
  • John Perring
    John Perring Aug 04, 2020
    Ok I will try holding on off button. Does the tv need to be on smart tv input or just the normal tv input. Hope this works im about to throw this thorn tv in bin. Sick of the android logo looping when smart tv input is selectedm
  • Andrew Taylor
    Andrew Taylor Aug 04, 2020
    No none of them do. You reset by reinstalling the Android software as detailed in the link.
    Your television has an On Off button on the set. Disconnect the wall plug. Count to 20. Plug back in and within 5 seconds press and hold the On button on the set.
    Thorn is not a good make. Samsung is the brand leader these days followed by Toshiba, Sony and LG in no particular order.
  • Andrew Taylor
    This is an Australian set? I can't find a maker for it, just auctions trying to get rid of them.
  • Andrew Taylor
    https://www.techhive.com/article/3316544...
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Posted on Aug 08, 2009
ranjonski
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
Posted on Dec 29, 2010
Anonymous
SOURCE: can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Posted on Jan 01, 2011
Als Diner
  • 4 Answers
SOURCE: Remote control code needed for this TV
The Insignia is-tv040919 is a Cytron and the code is 11326. But no Comcast multifunction remote contains that code -- so you cannot enter it manually and the 991 search function will not find it. I discovered the make and code because last year I installed the Insignia tv on a Comcast DTA with the small, black two function remote. That remote programmed quickly. When I moved that tv to the room with the cable box and multifunction remote, mayhem ensued. I got an $8 RCA 3 function remote today and it's working great on the Comcast cable box, a DVD player and, drum roll please, our old friend the is-tv040919.
Posted on Apr 07, 2011
I have the 55' 4k ultra thorn smart tv but its not playing my browser videos. Whyy please help!!!!
Check for Firmware or Software updates. You can also try the YouTube app and play from your smartphone.
Sep 02, 2018 | Ultra Televison & Video
Being a 4k smart tv, how do you add new apps apps?
Need to know which 4K smart TV. Each manufacturer has their own process.
Semper Fi,
Z
Feb 18, 2018 | Internet Computers & Internet
Fire tv remote
If you have a smart phone you can download the Fire TV remote control and use your phone instead of the cheap remote provided by Amazon Fire TV. I use it on my Iphone works great. Available for Android or Apple. Try it.
May 02, 2017 | Cell Phones
How to Add Apps to a Smart TV?
1. Verify that your Samsung Smart TV is connected to the
Internet using a wireless or wired connection. ...
2. Power on your television and select "Smart Hub" from
the main menu.
3. Select "Apps," then scroll to and select "Samsung Apps"
using your remote control.
Oct 19, 2016 | Televison & Video
Is there a way to upgrade the android software for a thorn 55' 3d smart tv? Mins about 12 months old and some of the newer apps dont work as good as they should. Cheers
Once you are connected to the wifi, go to settings and do a systems update. If there is an update, then it will update to the newer version.
Sep 11, 2016 | Android Cell Phones
I have a Samsung sch-r740c does it have IR capabilities
As far I can understand the cell phones do not have IR capability. You can check the features of your phone on the Samsung website.
Cell Phones
If you want to find out whether the phone can be used as a remote controller for your TV and other equipment then a) your phone should have Wifi and android / iOS capability and b) your TV should also have wifi connectivity and the TV supplier should have created an android/ iOS app for remote control through cell phone.
You can check the website of your TV / DVD/ etc manufacturer for any smart apps for remote control.
Alternatively you can use devices from other suppliers that can be used as universal remotes with cell phones.
5 Apps to Turn Your Phone into Universal Remote
As your phone is an Android smart phone you should be able to find the correct device or application provided your TV or other AV are compatible.
Aug 19, 2014 | Cell Phones
My thorn LCD TV when on the smart tv input setting doesn't work all it says is android it's the fifty five inch three D version
Fixed mate, had the same problem with my thron TV, iv posted the solution on your other post.
Aug 06, 2014 | Televison & Video
My thorn LCD TV the 55inch 3D version is not working on the smart tv input it just says android on the screen no buttons on the remote work
Ok have the same TV and it did the same thing stunk on the Android screen, To fix this i powered of the tv so it was in standby then above the RJ45 connector on the side of the tv you will see a update key (Find a pin or small screw driver ) then press and hold the button that is in the update key and whilest holding it power the tv on. Once you see the android robot with his shell open you can let go and it will come up with a list of options, select the reset all user data files to factory restore then select the restart system now, once all that is done give it a moment to boot back up as normal and it will allow you to set up like the first time it was turned on, :)
Led tv
is this on all source/input selections?
Apr 22, 2014 | Samsung BN94-05429D Main Board...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
