Question about Garden
How to adjust a clutch on a Lt 133 John deer lawn mower?
Posted by Glen McKinney on
Rajamohan RM
    Passionate:
    Visited the website for 10 consecutive days.
  • 187 Answers
5 Related Answers
Phil Rivera
  • 83 Answers
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Posted on Mar 30, 2009
Anonymous
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
Anonymous
  • 138 Answers
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Posted on Sep 06, 2009
philwalker78
Phil Walker
  • 608 Answers
SOURCE: I have a John Deere LT 133 lawn mower, when I
There will be a faulty safety switch somewhere. Most likely the one on the seat. Regards Phil
Posted on Apr 11, 2011
Anthony Browning
  • 640 Answers
SOURCE: John Deere LT 133 lawn tractor quits running after
Will it restart right away or does it have to cool down? If it has to cool down, then run it until it quits. Next remove the plug, reattach the plug wire, and ground the plug to the block. Finally try to start it with the key. If you get no spark or very weak spark then the ignition coil needs to be replaced.
Let me know how it goes.
Posted on Aug 18, 2011
What does the fuse look like on a john deere lawn tracter LT 133 serial number 2801914451?
Most likely like this.....
and it will be near the starter solenoid
Sep 29, 2014 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
Adjustment
On the front of the clutch, you should see 3 or 4 bolts with springs under them, they are the adjustment screws. Insert a .018" feeler gage between the clutch's plates and tighten the screws. You will have to go around to each screw several times as adjusting one effects the setting at the others.
Jul 27, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
John Deere LT 133 lawn tractor quits running after about 10 minutes.
Aug 18, 2011 | John Deere Garden
I have a John Deere LT 133 lawn mower, when I release the clutch/brake pedal the motor will will not continue to run.
Apr 10, 2011 | John Deere Garden
Have a lt 133 lawn tractor john deere. the back wheels are on with keysteel cannot get them off any suggestions?
The only thing you can do is soak them for about a week in Blaster, if that doesn't do it, you will need a torch, a small one, some of that stuff melts quick. I have some parts on my john deere soaking right now. The steering locked up, every time I go by , I squirt another shot on them, the stuff works great, If I can't get it, I'll be getting out the torch. Hope this helps.
Jun 05, 2010 | John Deere Garden
Need an owners manual for a john deere lawn LT-133
Sep 06, 2009 | Garden
Belt broken on riding lawn mower (john Deere LT 133) need belt routing diagram
Mar 30, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
