Question about Garden
My Hydrostatic transmission is slipping. starts out strong, then after 30 min. will barely go up the hill...ideas?
Posted by Mark Griffin on
  • STEVE SPAM REMOVER Jun 23, 2020
    please add year make and model information to your question
Vernon Taylor
  • Garden Master
  • 6,695 Answers
Perhaps the fluid has become contaminated and is foaming and/or one or more filters is being partially blocked after running a while. Perhaps also the fluid is boiling due to a lowered boiling point caused by contamination.
The fact it is ok while cold is likely to indicate the trouble is related to one or all of the above and so cleaning or replacing the filters and replacing the fluid seems the most appropriate initial action and if the trouble persists the next step will be to check the pump is maintaining the rated pressure when hot...
Posted on Jun 23, 2020
2 Related Answers
Tim Whalen
  • 3074 Answers
SOURCE: The transmission is slipping on
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on May 30, 2011
mike butler
  • 6468 Answers
SOURCE: Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Posted on Jul 31, 2012
LT1050 hydrostatic drive slipping will travel but willnot pull hill 345 hrs on unit.what do i look for?
Try this. When you try to go up the hill put your left foot under the Clutch/brake pedal and lift up. Does it speed up at all?
If it does your engine to transmission belt probably needs to be replaced. The hours you have on the tractor are about right for this normal maintenance repair.
Mar 22, 2017 | Garden
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Why does my tranny slip after 30 mins of use?
May be the drive belt is slipping. When did you last change or check it?
Is the belt shiny and showing small cracks ?
May 12, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
They are not fast going back but they are strong. The belt is looseing tent ion bad belt.
Jun 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
