SOURCE: I am looking for a
Its in stock here. But you may have to hurry. The part is out of stock neary everywhere else.
http://magictvparts.com/store/insignia-42/715t2830-2-2-main-unit/
Contact any service technician. This is not a service work; can be done with ease by a customer. Especially who is not aware in electronics. Gopakumar Gopalan Google
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Are you sure your meter is accurate? Chances are the set wouldn't power up at all with only 4 volt standby, as it takes 5 volts for the processor to work that turns the set on. Try testing the meter on a car battery and see if you get about 12.5 volts without it running
Testimonial: "You were correct. I believe meter is defective. It is a cheap clamp type and I see no calibration for it. New meter in near future. Then back to drawing board. Thanks for the help!"
