Question about The Computers & Internet
SOURCE: set up dl-523
Assuming you have connected your DSL/ADSL modem to the Wan port at the rear and connected one pc to the router via an RJ45 network cable into one of the Lan ports at the rear as it is easier to set up using a cable; first go to your wireless or wired connection in control panel>network connections, right click on it and select properties and and look on the TCP/IP line and highlight it and click properties and make sure obtain ip address is ticked, ok it and close window. Next get into your router by typing in your web browser 192.168.0.1, type admin as username and the password leave it blank, then click the advanced tab and in the left of the menu click WAN and select PPPOE if you are ADSL or DSL, if cable select Dynamic IP address, click apply Next type in your username and password given to you by your ISP to enable you to connect to the net. Next click the DHCP tab and the home tab and ensure that enable is ticked as this will automatically give your pc's an ip address, click apply and basically you should now get a connection.
Posted on Jul 09, 2007
SOURCE: panafax uf-s10
error 406 means you or the person your trying to fax has a password on the machine so you need to looking at that.,
Posted on Sep 30, 2008
SOURCE: i have a similar problem.
Press feature 985
Extension of vociemail is displayed. Dial 9
PSWD: RESETSMPSWD (73738767793)
Reset PSWD? Press YES
Login will be changed to default (1020000 for 3 digit EXT's or 120000 for 2 digit)
Posted on Jul 09, 2009
SOURCE: When I gointo my Facebook,
Try scan your system for Malware with software like Malwarebytes. Google and download, install and run.
Posted on Jan 23, 2011
SOURCE: Casio Wavereceptor WVQ 201-HA - module#4303 - I
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
Go to the above web site for full instructions for this watch.
Posted on Feb 05, 2011
Mar 11, 2014 | Computers & Internet
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
Oct 24, 2013 | Uniden DECT6.0 DIGITAL ANSWERING SYST W /...
Jan 03, 2011 | Casio Waveceptor WVQ-201HA-7BVCF Watch
May 21, 2010 | Uniden DECT 6.0 Cordless Telephone...
Jun 06, 2009 | ASUS P4S800-MX Motherboard
Apr 07, 2009 | Canon ImageRUNNER 1670F Copier
Sep 05, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
48 people viewed this question
Similar watch for sale on French ebay site with delivery from the United States. Translated site states that a booklet is included, which may be the instructions. You might try emailing the seller to ask if you could get a copy of the instructions at a minimal cost, or get answers to your questions.
https://www.ebay.fr/itm/254541018681
