Question about Speed Computers & Internet
How to Speed up Your Slow Computer? - Speed Computers & Internet
Posted by Electroclinic on
  • Larry Ng
    Larry Ng Jun 22, 2020
    faster than when new or just faster.
    no PC is fast enough, buy new one>?
    speed is relative metric.
    no PC told at all, not even a clue. wow.
    but in general, lets say you said my old PC is now slower than when new.
    1:all PCs with HDD go slower as the hdd ages.
    2:same for HDD near full or full.
    3:OS is corrupted (none told) as it ages it gets that way, for sure opening email attachments or visting bad web sites.
    4:PC is overheating all PCs slow down when too hot to save them selves from damage, CPU logic hard.
    answer #2:
    my PC is not slower than , now, wow. clear no?
    get SSD drive.
    add more RAM
    fresh install that unstated OS.
    get faster CPU
    and or a faster GPU (desktops) no PC told so the PC field is wide no?
    last , are all things slow or just gaming.
    no statement of what is slow. PCs do 10,000 things, are all slow?
    all mouse clicks slow? (is there a mouse?)
    NO PC told at all nor what options are in it.
    (size of ram, is PC with SDD< or slug HDD)
    how old is the PC, ? 1 year 10 years what"?
Rajamohan RM
    Passionate:
    Visited the website for 10 consecutive days.
  • 187 Answers
**STEP 1:**
- Press Ctrl + Alt +Delete. Select Task Manager.
- In Task Manager, click on the Startup tab on top.
- Look for the programs that are not required to load up in startup. Click and select the program and select Disable.
**STEP 2:**
- Press Windows (Start), type performance. In the popup menu, select Adjust the appearance and performance of Windows.
- Select Go Advanced tab and click on Change.
- Uncheck the box next to Automatically manage paging file size for all drives. Highlight the Drive that your Windows 10 is installed on. Select Custom size then change the Initial size and Maximum size to the Recommended size. After that, click Set.
- Click OK button. Restart your PC for the changes to take effect.
**STEP 3:**
- Press Windows (Start), type Defragment. In the popup menu, click on Defragment and Optimize Drives.
- Under Status, select the drive you want to defragment. To determine if the drive needs to be optimized, click Analyze. Click Optimize.
Note: If you have a solid-state drive (SSD) installed in your computer, you should not defragment it, as defragment SSD won't be helpful for PC performance but may reduce the life of the drive.
**STEP 4 :**
- Press Windows logo + R on the keyboard.
- Type prefetch and click OK.
- Under the Prefetch folder try deleting all the files.
- Type %temp% and click OK.
- Delete all the files under this folder.
(Some files might not get deleted under the above folder, you can ignore that).
**STEP 5**
- Type appwiz.cpl and click OK.
- Program and Features window will open.
- Check for any non-Microsoft software and unwanted application.
- Double click on it to uninstall.
**STEP 6**
- Press Windows logo + E on the keyboard.
- File Explorer will open.
- Click on This PC/Computer on the left.
- On the right, right click on Local Disk C.
- Select Properties.
- Under General, click on Disk Cleanup.
- Click on Cleanup System files.
- Check mark on all the boxes
- Click OK to start the cleanup.
**STEP 7**
- Type services.msc and click OK.
- Look for Superfetch, right click on it and select Properties.
- Select the "Stop" button. In the "Startup type" dropdown menu, choose "Disabled" and hit OK
- Scroll to Windows Search, right-click, and select Properties
**TIPS TO IMPROVE PC PERFORMANCE**: Please refer the support link - [https://support.microsoft.com/help/4002019/wind...](https://support.microsoft.com/en-us/help/400201...)
Posted on Jun 22, 2020
  • Anonymous Jun 22, 2020
    they never once said windows.
    might be Chromebook or well anything.
Mikey
    Top Expert:
  • Speed Master
  • 6,489 Answers
Wipe everything!
Do a factory reset to when it was new.
    not if it was slow new and now. right?
    NO PC even told, it can be ANYTHING,from any decade. even sold at garage sale with XP. or linux.
What is happening with AOL? I have been having lots of pop ups, slow computer and AOL telling me they are having problems? My computer very slow?
Is you computer slow when using software offline? If so, it is either AOL or your internet. Don't judge the speed strictly by going to AOL. Go to Speakeasy Speed Test and test your internet speed. If that shows your internet is running at the speed you are paying for, it si AOL having trouble. You don't say which browser you are using, but most browsers have an option to block pop-ups. Make sure it is on.
Run a virus scan on your PC to see if it is infected. Also defrag your hard drive to speed it up some.
Nov 01, 2014 | Computers & Internet
Tip
Computer Running Slow?  The guaranteed way to speed up your computer!
<span>Computer running slow? Nothing is more frustrating than a slow computer. Speed up your computer now with our proven computer optimization service. As a leading Microsoft&reg; Partner in the online computer repair industry we have access to the latest tools and resources from Microsoft&reg; and others to </span><span>speed up computer</span><span>, </span><span>computer running slow</span><span>, <a href="http://www.mycomputerexpert.com/speed-slow-computer.php">fix slow computer</a> and Netbooks running Windows 7, Vista and XP.</span>
on Jun 26, 2011 | Computers & Internet
Tip
Slow computer Performance causes and solutions
Slow computer causes and solutions how to speed up your pc?
Computer users often feel from time to time will slow down your computer starts up, and memory is not enough, the software is running slow, we can use many ways to clean up WINDOWS.
1. Do not install software easily. Online there are varieties of optimization software, but not many really useful, it will take up your hard disk space, and some software, usually with a virus.
Optimization of different operating systems in different ways. For example, for WINDOWS XP, WINDOWS XP every time you start when the blue scroll bar to scroll to be many times. We can reduce the time it’s rolling, to speed up the boot speed of the computer.
Open the Registry Editor, locate the HKEY-LOCAL-MACHINE \ SYSTEM \ Currentcontrolset \ control \ sessionmanager \ Memorymanagement \ prefetchparameters, the right to find Enabelprefetcher primary key, and change the default value of 3 to 1, then it will scroll the scroll bar reduced.
2. For Disk Defragmenter Computer was used for a period of time, the system disk defragmentation is necessary. Recommend that you try Advanced Defrag.
3. Clean up garbage Internet will often leave a lot of junk, we can use the Registry Easy to clean the hard disk.
4. Timely optimize registry WINDOWS registry has a feature that continues to expand, this will inevitably cause the computer to slow down. Registry Easy can master to clear
"Why my compute is running slow?"--To speed your computer up, I highly recommend you get a free computer scan to detect and repair PC system errors from now on.
on Jul 01, 2010 | Computers & Internet
Computer too slow to play song
Computer memory and processor speed are the things that make a computer too slow for music playback. Also check your system for routine maintenance. Use the Computer Cleanup utility in Windows. Although this will help, the system may not have enough memory or processor speed to playback.
Jul 31, 2010 | Propellerhead Reason 4.0 Upgrade - Windows...
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
Is there any way to speed up Windows Vista. Its standart Vista Home Premium, Mcafee antivirus was on it. Is there a program witch can speed up my laptop with windows vista. help please. its too slow :)
please let me know your
Machine configuration.
Processor speed,Ram,Hard Disk Size.
I have to assist you remotely to do this.
There are so many reasons for a laptop to be slow.
Dec 08, 2009 | Microsoft Windows Vista Home Premium with...
BOARD RUNS REAL SLOW
i think it is not true. because speed of computer depend processer and ram . u can chang high config . ram than using . it can help little make high speed. temp file can make slow so time by time we remove this file. virouse can make slow computer. if bord is short it make hang computer.
Nov 04, 2009 | Computers & Internet
SLOW
hi..
u can improve ur computer speed by using a ram of higher speed. by purchasing a 4gb ram will kep up ur computer speed very high....
rate me
Jun 16, 2009 | Acer Aspire One AOA110-1588 Notebook
Computer runs slow
Slow computer can also cause by alot of software install on your system that is using the resources of your computer like the Memory and Processor, so first thing you can do is to remove some unneeded software that you have on your computer and then after that try also running a scan on yuour computer with a good anti virus and anti malware because can also slow your computer down...
May 07, 2009 | Computers & Internet
Slow Internet Browsing
sir better to contact your ISP provider or internet provider about this. Sometimes heavily load on their connection will slow the speed of the internet. i experienced that myself.
thank you for using fixya
CHARCOIS
Jan 19, 2009 | Dell Optiplex GX60 PC Desktop
Computers & Internet Logo
141 people viewed this question
Top Speed Computers & Internet Experts
Vernon Taylor
Pcm2048
XUNICORNX
XUNICORNX
Level 1 Expert
Are you a Speed Computer and Internet Expert? Answer questions, earn points and help others
