Air Tools & Compressors Logo
Shyam kishor Posted on Jun 22, 2020
Air compressor show no control power - Air Tools & Compressors
rick rhymer
Level 1:
Habit-Forming:
New Friend:
  • Contributor 64 Answers
  • Posted on Jun 22, 2020
rick rhymer
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
29091
Points
78
Loto. Then check the control line fuses. Then the power supply or transformer depending on controller voltage to make sure they are outputting the correct voltage. Check to make sure you have power in. If u drop a leg that your transformer feeds off of. No power to controller
Ingersoll Rand Part# 39875158, SG Intellisys Controller showing overdurrent when motor is ok
check if the voltage supply is ok or the tranformer on the panel is not giving over voltage
3answers
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
I have a ssr ep 100 and the intellisys says no control power ive tryed to clear it but it wont
Probably have a bad High air temp. switch located in the end of the compressor air end. It has control power run thru the switch. If the switch opens on temp or just goes bad you lose control power which will come up on screen as control power loss. Replace HAT switch.
My air compressor show continusly the alarm NO CONTROL POWER
No Control power is often caused by high airend temp or a faulty High AirTemp. switch(IATS Switch i.e High Air Temperature Switch). I suspect the IATS switch is bad and opening prematurely/coolent level not suffecent or bad filter condition because the att. temp. probe located next to the switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power and series to emergentcy switch having two NC connection but if press emergency it gives alram emergency but if you remove cable 36 inintellisys control pannel. Thus the controller issues a No control power . This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Compressor stopped working. Air handler works okay. Checked wiring in thermostat-that is fine. Air handler is not frozen up. Breaker shows fine on meter.
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
The compressor on my ge ASH10ABS1 window air conditioner starts and operates fine but won't shut off even when the temp control is lowered. What's up?
when attempt to I power up my GE window unit, a message
' E1' shows, and the unit does not start. what is it telling me ??
The compressor trip at main breaker
possible causes , do not use ext. cord on compressor unless it's HEAVY gauge, also if you have any thing else running on the same breaker, It might cause it to pull too much power.
1helpful
I have an amana air conditioner (ace245e). It
seems like the control board is bad,
if you have experience with electricity you can test the fan & compressor bi-pass the power from the board to the compressor terminal, if the compressor run you know for sure the board is bad
3helpful
99 expedition air suspension compressor runs every couple minutes
It is normal for some cycling of the compressor as the ride heights change and the compressor vents and fills air springs. Info:
Air Compressor
The air compressor:
  • Is not interchangeable with the rear air suspension (RAS) air compressor.
  • Consists of the compressor and vent solenoid; neither are replaceable as individual items.
  • Is a single cylinder electric motor driven unit that provides pressurized air as required.
  • Is powered by a solid state relay, which is controlled by the air suspension control module.
  • Passes pressurized air through the compressor air drier that contains silica gel (a drying agent). Moisture is then removed from the compressor air drier when vented air passes out of the system during vent operation.
  • The drier may be replaced separately.
  • The drier has dual ports and is not interchangeable with the RAS drier.
The vent solenoid:
  • Allows air to escape from the system during venting actions.
  • Is part of the air compressor cylinder head.
  • Shares a common electrical connector with the air compressor motor.
  • Is enclosed in the cylinder head casting, which forms an integral valve housing that allows the valve tip to enter the pressurized side of the system.
  • Has an O-ring seal that prevents air leakage past the valve tip.
  • Opens when the air suspension control module determines lowering is required.
  • Provides an escape route for pressurized air when system pressures exceed safe operating levels.
  • Has a 1792 kPa (260 psi) internal relief valve.
  • Is installed with the air compressor as a unit.
Compressor Relay
A solid state relay is used in the air suspension system for compressor control. The relay incorporates a custom power metal oxide semi-conductor field effect transistor (MOSFET) and ceramic hybrid circuitry. The relay switches high current loads in response to low power signals and is controlled by the logic of the air suspension control module.
The compressor solid state relay is energized by the air suspension control module to have high current flow from the battery to the compressor motor.
Control Module
NOTE: The 4WAS control module is also used for the RAS system. The internal processor recognizes external circuitry to determine if it is installed in a 4WAS or a RAS system.
NOTE: The air suspension control module is calibrated with information from the air suspension height sensors. A new or swapped air suspension control module requires the ride height adjustment calibration process to be performed.
A microcontroller-based electronic air suspension control module controls the air compressor motor (through a solid state relay) and all system solenoids. The air suspension control module also provides power to front and rear height sensors. The air suspension control module controls vehicle height adjustments by monitoring the two height sensors, vehicle speed, a steering sensor, acceleration input, the door ajar signal, transfer case signals and the brake pedal position (BPP) switch. The air suspension control module also conducts all fail-safe and diagnostic strategies and contains self-test and communication software for testing the vehicle and related components.
The air suspension control module is interchangeable between the RAS and 4WAS system.
The air suspension control module monitors and controls the system through a 32-pin two-way connector. The air suspension control module is keyed so that it cannot be plugged into an incorrect harness. There are two sides of the harness connection to the air suspension control module. Each is uniquely colored and keyed to prevent reversing the connections.
Pressure Relief Valve
The pressure relief valve (PRV) protects the rear air suspension components by venting the system to a specific pressure in the case of a system malfunction. The system will decrease the pressure to an acceptable level to maintain vehicle height. In the normal operation mode with normal system pressure, the PRV is constantly closed and does not have any effect on the system performance or function. The PRV is replaceable without any air lines.
  1. If the concern remains after the inspection, use New Generation STAR (NGS) Tester connected to the data link connector (DLC) to retrieve continuous diagnostic trouble codes (DTCs) and to execute On-Demand Self-Test diagnostics for the air suspension control module.
    • If the On-Demand Self-Test is passed and no DTCs are retrieved, go to the Symptom Chart to continue diagnostics.
    • If DTCs are retrieved, go to Air Suspension Control Module Diagnostic Trouble Code (DTC) Index in this section.
    • If the air suspension control module cannot be accessed by NGS Tester, go to Pinpoint Test A.
Self-Test
Verify that the following conditions are met before running the On-Demand Self-Test.
  • All doors, liftgate, and liftgate glass must be closed.
  • The transmission is in PARK.
  • The BPP switch is not pressed during the test and the parking brake is not set.
  • The accelerator pedal is not pressed during the test.
  • The vehicle is not in 4L mode.
  1. Fulfill the pre-conditions.
  1. Install a battery charger for the On-Demand Self-Test to prevent battery drain.
  1. Run the air suspension On-Demand Self-Test.
  1. Record all listed DTCs.
  1. Retrieve stored DTCs.
  1. Troubleshoot any On-Demand Self-Test DTCs first.
  1. Retest and clear DTCs after repairs.
Volkswagen vanagon air conditioning system
Most of the control relays for the vanagon AC can be found on the drivers side D pillar under the plastic or in the cabinet if you have a cabinet. Best to buy a 'Bentley' factory service manual to help out. Cane Rattler...1989 Vanagon
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
