Question about Health & Beauty
How do I fix my Homenics bathroom scale after it was flooded?
Posted by Harriet Darling on
How do I remove the batteries to replace them?
Hello, Joanne -
WeighMax manufactures more than one model of bathroom scale. See:
http://www.weighmax.com/products/bathroom-scales-1.html
Not all the WeighMax bathroom scales take the same kind of battery. If your scale is one of them listed on the web page cited above, click or tap on the link for the information on the scale and look for the information on Power to find out the kind of batteries needed.
I do not find any instructions for where to find the battery compartment on any WeighMax bathroom scale. Therefore, I suggest you contact WeighMax Technical Support and ask. You will probably need to provide the model number of your bathroom scale. This is the link to the WeighMax Contact Us web page:
http://www.weighmax.com/contacts
Best wishes.
May 15, 2018 | The Health & Beauty
My bathroom scales keep reading error im not sure what to do to fix the problem
Try this article. If it works for you, please rate me.
https://eatsmartblog.com/2013/02/19/three-things-to-know-before-using-a-digital-bathroom-scale/
Feb 07, 2017 | The Health & Beauty
My Dibal scale stop printing
problem. I have no digital display on my bathroom scales.Do you think I should purchase another set from HoMedics. Jeffrey Olsen
Jul 11, 2013 | Balance Health & Beauty
The Taylor bathroom scale is giving an error message. How can I fix this?
If the scale is moved or bumped, or the battery is replaced, the scale needs to be initialized before use.
To initialize, just press on the platform with your foot. The display will turn on and off. The scale is ready for use once again.
Sep 26, 2010 | Taylor 5593 Body Fat/Body Water Scale
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Oct 03, 2009 | Dmm Elscale Healthsmart Glass Electronic...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
