HP uses the error 3f0 to indicate a problem with the Optane memory (Intel Rapid Storage) or hard drive. It could be an issue with the Boot configuration, missing or damaged system files on the drive or the boot record or Optane memory. You should test the hard drive with the HP Diagnostics test. Make sure that Legacy Boot support is disabled. Then in the BIOS tools, see if the BIOS sees the Optane memory. For desktops, see https://support.hp.com/us-en/document/c06101701 .
For a laptop, make sure that the drive cables (power and data) are fully seated. (Use appropriate tools to stay grounded relative to the system and look for the Maintenance and Service manual for your model.) See https://support.hp.com/us-en/document/c01443463 for the full set of steps.
Note: accessing these tools before Windows boots can be difficult. I usually hit the appropriate function key multiple times starting immediately after turning on the computer. It can be hard to get the timing from a Restart on Windows 10 when fast boot is enabled.
I hope this helps.
(The solution might require replacing the hard drive and then restoring files from a good backup. I hope you have backups of your data.)
no pc TOLD, NOt a CLUE, 10,000 MODELS MADE.
SORRY CAN'T GUESS THAT.
BAD HDD TOPS LIST. TEST HDD. FIRST.
surly you can read the service tag and tell
or go to HP.com
and they will beg you too all the same question.
1: what PC, what OS
2: run diagnostics yet. oops hdd is bad.
3:etc
they asking HP, ok?
step one is here, go there and do it now.
https://h30434.www3.hp.com/
