Question about Power Computers & Internet
My troybilt XP 7000 HAS NO POWER TO THE PLUGS AND NO DISPLAY ON THE PANEL.
Posted by Ken Ford on
  • Larry Ng
    Larry Ng Jun 18, 2020
    troybilt XP 7000 computer.
    check batteries first.
    ops it is a portable AC power generators.
    power to the spark plugs you meant?
    so that means the starter works right?
    you failed to mention starter.
    I think you meant it will no not start.(either way)
    the LCD uses a battery for sure , and is dead.
    check battery and all fuses first.
    RTM, lost the manual get it read and do the steps stated in the manual."starting"
    the spark is Piezo type, so if spark is dead
    hand cranked (pulled) that means a safety inerlock of some kind has disabled the spark on purpose (low oil?) or the on/off switch in the off position./
    here it is below see that starter?
    id bet the battery to it is dead.
    it is no computer so is off topic here.
    or is this a gasoline powered computer?
  • Anonymous Jun 18, 2020
    did it run before, or pulled it of of the box.
    we can not guess history GHM, gen history matters.
    first check why the starter motor see above
    is dead. if a new generator out of the box and lost the instructions say that first.
    if new, oil is first then battery hook up and charging it first if it is low, ask.
    last is fuel, so you dont wreck it, guessing./
Rajamohan RM
    Passionate:
    Visited the website for 10 consecutive days.
  • 187 Answers
  1. Check the fuel. There's always a chance that you may be getting a false fuel level indication when the fuel tank is actually empty. ...
  2. Check the Spark Plug. Find out, are there signs of wear and tear in the spark plug? ...
  3. Check the Air Filter. ...
  4. Check the Battery. ...
  5. Check the Oil Level.
Posted on Jun 18, 2020
No power to the stepmill
Start by confirming power at the wall outlet. There should be at least 110v AC at the wall. Also confirm 12v DC output from the power supply where it plugs into the bottom of the machine. If you have power there, I would suggest pulling the side panel and checking the wires just behind the plastic panel, where the power supply plugs into the bottom of the machine. A very common issue with these machines is a simple loose ground wire on the grounding plate. If all of the previous checks provide the correct voltage, continue following power to the relay board and from there to the console. Your problem lies where the power stops. Video about Multimeter Testing
Oct 28, 2013 | Stairmaster Stepmill 7000 Pt
Tbp6040'trimmer head disassemble
www.troybilt.com/equipment/troybilt/ownercenter
Oct 22, 2013 | Troy-Bilt 25cc 4-Cycle Straight-Shaft Gas...
Pull start not turning engine. not engaging
Take it off and you will see a pawn(s) that stick out and engages the flywheel when the rope is pulled. You will also see why that is not happening. Stuck ,broken or stripped pawn maybe.
Aug 24, 2013 | Troy-Bilt 25cc 4-Cycle Straight-Shaft Gas...
Ce 7000
This is a common fault when the 7000 series gets older. The display drive circuit will normally need repairing.
if anyone needs a Casio CE-7000 or TK-7000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
Jul 02, 2013 | Casio Parts Cash Register PC Desktop
I have a troybilt 7000 gas generator that trips the main output breaker when under a load after 5 minutes
1. Make sure that the generator limit is not being exceeded.
2. Try checking and raising the rpm. If the engine can not sustain the load from the generator, it can/will trip the breaker.
3. If the carb is dirty or the engine runs poorly it can trip the breaker. Tune up the engine, clean the carb, make carb adjustments to correct substandard running conditions.
Jan 21, 2013 | Garden
Troy-bilt extenda panel xp 7000 generator paney will not display
My Troy-Bilt XP generator doesn't work it runs but it doesn't seem to be put out any electricity. It's new what could the probelm be
Jul 22, 2012 | Briggs & Stratton 20-Amp Extenda Panel -...
7000 PT will not start up (display flashes)
On that relay board their should be 2 lights engaged:
1.power 2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
Feb 11, 2010 | Stairmaster Stepmill 7000 Pt
How come there are no manuals for the troy-bilt Model#303531 / TB340 XP? Not even on TroyBilt website.?
The unit may say "troybilt" on it but may have been made by another company, like MTD, RYOBI, or Homelite. Check out those manufacturers.
Sep 25, 2009 | Troy Garden
Looking for a power adapter that plugs into the cigerette lighter for my Nav-Cam 7000 and I can't find where to purchase one.
go onto ebay, they start from 99p + p&p. they have car chargers and 2 & 3 pin plug chargers. good look.
Mar 10, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Require ati 7000 64 m pci vga card drivers
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
There is the divers if u running XP as OS, if not change the OS to that one you run
Im not sure that the issue is the 7000, it can also be your memory.
How mutch memory do you have in your pc?
Upgrade the momory solve a lot of problems whit gaming.
Good luck
Dec 11, 2008 | ATI RADEON 7000 PCI Graphic Card
Computers & Internet Logo
42 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
