Question about Refrigerators
The refrigerator bulbs need to be replaced. How can I remove the cover to make the bulb replacement?
The refrigerator is Viking DFSB423D.
Posted by Shiying Wang on
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 33,337 Answers
  • Shiying Wang
    Shiying Wang Jun 17, 2020
    It is very helpful. Thank you very much.
  • Andrew Taylor
    Andrew Taylor Jun 17, 2020
    you are very welcome :>)
5 Related Answers
Ken Bledsoe
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
Anonymous
SOURCE: How to change Headlight HID bulbs in Infiniti QX4
It is really not that difficult for an 01 qx4, and if you order the bulb online you'll save enough money that if it takes you two or three tries (and bulbs) you'll still save over what the dealer or a mechanic would charge you:
Don't touch anything on the new bulb besides the plastic base (don't touch the glass!)
1. Make sure you disconnect the battery before anything else (you don't want to get shocked by these high voltage babies). If you're replacing the passenger side bulb, take the battery out for more room to work, especially to see what's going on in there (you can undo the air filter case on the drivers side for the same benefit, again--disconnect the battery first). 2. Find and unscrew the round, black, plastic lid behind the headlight, it's up and to the left. 3. You'll see a shiny metal connector with electrical warnings printed on it and Michael Jackson glove looking wiring attached to it. Turn that gently to the left to open up access to the actual bulb (you'll now see the bottom/back of the bulb--a black circle with a small metal tip in the middle). 4. Unhook the two metal braces that hold the bulb in place (push in gently to let wire out--kind of like unhooking a bungee cord or unsetting a mouse trap). 5. Pay attention how the two divots on the bulb case line up with the little nubs at the top of the encasing (you have to put the new one in lining up the same way.) 6. You can now take out the bulb. You might consider practicing the replacement sequence with your old bulb that you just took out before sticking the new one in there--just to get the hang of it so you aren't banging the new one around. 7. Once you've got the bulb back in there just put everything else back in place in reverse order. 8. Wash those dirty hands and try turning on your lights. 9. Go celebrate your automotive victory by driving somewhere at night!
Posted on Aug 28, 2009
omaharox
Mike
  • 166 Answers
SOURCE: How do I open the plastic shield covering the
Use a butter knife and insert it in the slot between the cover and white plastic holder and pull the knife lightly twords you.
Do this on both sides and the cover should come out.
Use 40W bulbs for replacement.
Posted on Jan 17, 2010
Anonymous
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
ricsindy
Richard Weimer
  • 53 Answers
SOURCE: How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Posted on Mar 09, 2010
How do I change the freezer lite bulb?
A bulb is a bulb is a bulb. Unscrew and replace.
It might be behind some cover - if so remove the cover and unscrew and replace and put the cover back on..
Sep 04, 2015 | Maytag Refrigerators
How change freezer light bulb on model LFC 21776
yes to both, and I believe to remove the light bulb cover you gently lift up and out to gain access to the bulb.
Sep 18, 2014 | LG LFC21776ST 21 CF French Door Refer Cab...
How to remove cover so I can change bulb
I think the best way to explain how to change the light bulb can be found on page 26 of the=> JFC2089HE User Manual If you have problems with the above link then click HERE and then enter your model number and answer the questions above the plaace you enter model number. I will be here to answer any questions you may have Thanks Sea Breeze
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
Dec 19, 2012 | Jenn-Air JFC2089HE French Door...
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Mar 21, 2011 | Kenmore 74889 / 74882 / 74884 Top Freezer...
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
HOW DO I TAKE OFF LIGHT BULB IN REGRIGERATOR SO I CAN CHANGE IT IT'S NOT UNSCREWING
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
Sep 30, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Fresh Food Section
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How to change a ge refrigerator light bulb
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
