Question about Sony Video Cameras
How to fix ( low temperature cannot access media warm the camcorder) Error :91:01 in sony hdr-pj50e
Posted by mk k on
  • Tony Parsons
    Tony Parsons Jun 17, 2020
    As it says - warm the camcorder ! Put it in the airing cupboard for an hour or two.
5 Related Answers
Anonymous
SOURCE: sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Posted on Feb 25, 2010
Anonymous
  • 338 Answers
SOURCE: Where can I find a replacement LCD screen for my
Take a look on Ebay if you prefer a used one, but having job done properly is always best.
Posted on Jun 01, 2010
Anonymous
  • 338 Answers
SOURCE: Hi i have a Sony hdr CX550 handycam camcorder
Most mics will work if the plug fits the socket on camera and it fits on the hot shoe okay, I never use Sony mics on my Sony camera, you end up paying for the name, not the item.
Posted on Jun 19, 2010
drumman3
SOURCE: Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
Posted on Aug 17, 2010
Anonymous
  • 3 Answers
SOURCE: E:31:00 Error Code on sony camcorder
Recently, I faced the same problem with a Sony XR-155 camcorder while being on vacation. Fortunately, I managed to recover my videos. First, make sure that you as little as possible to the hard drive in the camera menu, so I would not recommend to rebuild the image database or to reformat the drive.
Connect the camera to your PC in the same way that you would usually do. When I tried to access the drive in Windows Explorer, I got a message that the drive was not readable and needs formatting. You do NOT want to do that. I decided to make a full backup of the drive first, so that I could safely fiddle around later on.
The program that I used is Paragon Drive Backup. It gave me a few error messages during the back-up, which I all ignored, and after about 1.5 hours the copy was ready. The next step was to mount the image as to a free drive letter. I figured that I would need some kind of data recovery tool to extract the data, but to my surprise, the mounted disk image was readable in Windows Explorer as if no problem had ever occurred. Luckily, I was able to extract all of my videos from the camera in this way.
Of course I do not know for certain whether this technique also works in your case. For instance, it could be the case that the code E:31:00 is a generic HDD error message and therefore, it might be the case that your camera has a different problem than mine had. However, I think it is worth the shot to try to recover your data in this way (I assume Backup & Recovery 10 Suite does the same trick, a demo version is available on http://www.paragon-software.com/downloads/home/).
This procedure of course does not fix your camera (what I understand from various massages across the internet is that you should send it to Sony to get it repaired), but at least you might be able restore your data. I hope that you will be successful, good luck!
Posted on Sep 24, 2010
How do I fix/clean moisture dew condensation on my sony hdr-pj10 camcorder projector
Try putting it in a container of uncooked rice for 24-48 hours. The rice will draw the moisture out.
Jul 01, 2014 | Sony Handycam HDR-PJ10 Camcorder
HDR-cx360V - E:91:01 - Error does not go even after reset/power off.
this is a manufactures melfunction.sony will fix it for about $294 or give 15%of on a new one.buyer be ware.
Jan 20, 2013 | Sony Handycam HDR-CX360V Camcorder
After I formatted using windows explorer Hard drive of Sony handycam ( HDR-XR500VE) message HDD FORMAT ERROR POPPING UP. How to resolve, please?
You need to format camcorder hard drive through Format option in camcorder menu itself.
Please check camcorder menu and hard drive section for Format option, this will delete all files on hard drive and solve your problem.
Thanks.
Feb 20, 2011 | Sony Handycam HDR-SR1 HD Camcorder
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
Jan 19, 2011 | Sony Handycam HDR-XR520 High Definition...
I need to find a replacement LCD for my Sony HDR UX10 Flash Media Camcorder. Will any of the other HDR models similar to this work if I use the LCD screen for them?
The LCD (part number 8-753-241-14) can be purchased from www.encompass.com for $69.78.
This same part is used in the following models:
HDRSR11
HDRSR12
HDRUX10
HDRUX20
HDRHC9
DCRHC48
DCRDVD910
Dan
May 04, 2010 | Sony HDR-UX10 Flash Media Camcorder
Error code E:31:00, hdr-xr100 camera. will not format, access harddrive, record, etc
The solution is very simple if your camera has a memory stick slot! For those who has any Sony camera with memory stick slot, try this:
3- Go to "Manage Media" again, then to "Format Media", so choose to format the HDD! - Now that you are running the camera from memory stick, you'll not have any problem to format the HD.
At least worked with me! I think it worths the try!
Nov 27, 2009 | Sony HDR-XR100 AVC Camcorder
Sony Camcorder HDD error
Hi There ...anyhow i have solved this problem
Regards,
Lionel
Nov 17, 2009 | Sony HDR-XR100 AVC Camcorder
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
Oct 25, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Disc Access error
Clean the optical lens in camera with nice quality soft cotton swab.
Jun 25, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Video Cameras Logo
48 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Richard C Cohen
Richard C Cohen
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
