Question about Pool & Spa
Where can I find a replacement motor for Aquaglass pump model #F42E92A03
Posted by C McCoy on
I have an aqua glass pump model #F42E92A03 I'm trying to remove the timer circuit to use the pump for a pond application. The motor is 110v has 3 wires red, back. White.
I couldn't find any info in that pump model, looks like some kind of jet pump but most likely the time was controlled by an outside timer that controlled the power to the pump. Wherever the power button was that's where the time is. Well anyway that things probably too powerful for a pond lol
Jun 07, 2015 | Pool & Spa
AquaSense by AquaGlass
The control & pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system will include the following items:
· New Pump
· AirStreme Control box and topside control
You will change out everything from the old system with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/0108-205005.aspx
US Parts Center
Nov 24, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Our aquaglass whirlpool tub runs for about 10 minutes then cuts off. It will come back on for just a few minutes then cuts off again.
When a motor is doing this it is overheating. You should replace the motor as soon as you are able to. This could cause more trouble for you soon because the motor is over heating.
US Parts Center
Sep 02, 2013 | Home
Where can i purchase an on/off switch for my aqua glass whirlpool tub
We have all the old Aquaglass switches or the replacement for the ones that are not made anymore. Aquaglass Parts
Contact us at: [email protected] or Toll Free 888-521-6183
Rod
US Parts Center
Jan 15, 2013 | Home
I have an Aqua Glass tub in the master bedroom. Today I filled the tub to clean the tubes out and the pump won't work. It almost sounds like it's lock up? When you plug it in and push the ON/OFF...
We service a ton of Aquaglass products. Need to know what kind of control we are talking about. Is this an electronic button you are pushing or an air button you push down?
US Part Center
Aug 13, 2011 | Home
Whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
Feb 14, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
