Question about Furniture
If its available comparable wine cooler cwc3200 power board?
Posted by michael veksler on
Rajamohan RM
    Passionate:
    Visited the website for 10 consecutive days.
  • 187 Answers
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
Anonymous
SOURCE: Durabrand wine cooler
I bought 2 of these wine coolers and both of them ****! You would be better off returning it if you can or putting it in the trash.Both of mine did not keep them cool. At first they worked for about a day and then they stopped. They refrigerate around 70 to 76 degrees and stay there.
Posted on Jun 21, 2008
Sheldon Dedek
  • 909 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
mrbobfixit
Robert DeStevens
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
Anonymous
SOURCE: Where can I get a Haier swwitching power supply
Call 800-313-8495 for Haier Parts Dept.
The upper and lower are 2 different part numbers.
Posted on Jul 15, 2010
My cooler arrow does not respond or the power. It gets warmer. Now I can't turn it down
at the front bottom of the frig open the cover inside there is a electronic board order a new one very easy to upplug
Apr 26, 2014 | U-Line 15WC Wine Cooler
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Hys60 12 kd 130c circuit
Hi, This is very easy designer this Board, I 'm a repair center from this boards.... what do you need from shematic this board, question for my and I give help for you from Brasil in www.indexdata.com.br.....
Jun 21, 2013 | Avanti EWC-12 Wine Cooler
Cuisineart CWC-600 wine cooler no power
Yup you bet, all you need to do is connect a $15 temperature control you can get from any appliance store, fix it to the back of the machine and find a way to ge the probe into the fridge, wire it In series with the compresser and bang you have a working cooler. If you need more info just let me know Good luck
Sep 07, 2012 | Cuisinart Private Reserve CWC-600 Wine...
Wine cooler displays temperature setting but does not run or cool wine.
It's 1 of 3 things...
A. The fans are not turning. Remove the back, and see if the fans are getting 12 volts, and spinning freely. Remove them and clean off the dust from the heat sink.
B. The Peltier Chip is shot. If the fans run, check for 12 volts on the power connector that's on thelower left of the curcuit board. If there's power, but no cooling, the Peltier is shot. These are available from E-bay for ~$13, but it's a major dissassembly to get it out.
C. If you don't get 12 volts to the fans or the Peltier chip, replace the circuit board.
Dec 15, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Furniture Logo
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
