Question about Radio Communications
These radios are great but why put talkback on a radio when itll only work on am..we use fm mainly in the uk..is there anyway of modding it so itll work on fm please
Posted by Stuart Eggleson on
Vernon Taylor
  • 6,663 Answers
The short answer is no -- the difference between AM and FM is too great though some CB radios were made dual mode, like the President Veep I used to own.
Some CBs that found the way into Britain were powerful sidebanders that offered similar capabilities to unlicensed CB-ers to that official radio hams had to sit exams to enjoy. Some radio hams found it cheaper to have those top-line CBs modified for use on the 11 metre amateur band.
It would be no help to you to obtain a standard FM CB as when the UK was forced to legalise CB radio under the Treaty of Rome, they legalised it at a different frequency as the American frequency was already allocated to radio control, bleepers and other things. Special CB sets were manufactured for the UK market.
Posted on Jun 15, 2020
Midland 95 plus
Again another radio with illegal mods to go out of freq bands and FM is not authorized here by the FCC in the USA. I won't provide solutions to anyone with these radipo types. You want more bands, freq.s, power? Go Ham..
May 14, 2014 | Radio Communications
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy dx 88 hl works great but the talk back won't work on am but does work on pa what is wrong
if you hooked it up its wrong but I assume you didn't.First of all talkback is a feature that allows you to hear your voiceand you don't5 need a radio check because you can tell by your own voice how your radio sounds if you want it to work on am you need to attach a 33ohm resistor from the positive to the neg of the external and pa plug ins. the talkback will be on all the time by the way.
Sep 27, 2013 | Galaxy Radios DX- 88HL Base CB Radio
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
What mods can i do to my cobra 19?
tune up, swing mod, talkback, any thing that can be done to a cobra 25 ltd can be done to any 40ch cb.. just add a power mic$17.99 or a good echo mic will make a huge difference.
Feb 07, 2011 | Cobra 19 Ultra II CB Radio
I want to put talkback on my cb myself.
Hi Overton2525,
I used to install all these talkback and sound-effect devices in radios for the truckers, and most were so elaborate, that I did it in kit form. You must be pretty handy with soldering, so here we go with a bold little adventure. CB Radio Magazine has a nice inexpensive project that won't take very long to install.
Here's the link to their pages:
http://www.cbradiomagazine.com/April%202007/Adding%20talkback%20to%20your%20radio.htm
Your radio meets all the requirements for this project. Let me know how this Mod works out for you. Thanks.
Regards, Bill
Sep 18, 2010 | Cobra 29 LTD CB Radio
Just bought a 142gtl and looked it up online. I
Don't get crazy into mods. Some are good some are bad.
Really all you want to do is a peak and tune on it. The cobra 148 has great audio already. The most I would do to it is turn up the modulation all the way, and the AM power, then put a swing mod in. That will get you max wattage. 2 watt dead key.
Talkback is only necessary if you are going to be putting an echo board in so you can hear how the echo sounds.
Jan 30, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
