Question about Home
How to remove mold from tile/ grout shower - Home
Posted by nate mackler on
Andrew Taylor
    Top Expert:
  • Home Master
  • 34,068 Answers
Go to Home Depot and buy a spray bottle of Tilex. Spray on and leave for 5 minutes, lightly scrub and rinse. Leave it to dry, spray again and leave it.
Tilex® Mold and Mildew Remover Spray - Clorox
clorox.ca > products > sprays > tilex-mold-and-mildew-remover-spray
Tilex® Mold and Mildew Remover Spray kills common household mold, mildew and bacteria on a variety of surfaces. Powered by Clorox Bleach, this mold and mildew disinfectant spray kills common bacteria found in homes.
Tilex Mold & Mildew Remover, 946-mL ' Canadian Tire
www.canadiantire.ca > Living > Bathroom > Bathroom Cleaners Rating: 3.6 - ‎5 votes
Tilex Mold & Mildew Remover removes mold and mildew from most surfaces Instantly cleans tile, grout, toilets and fiberglass.
Posted on Jun 14, 2020
  • 2 more comments
  • STEVE SPAM REMOVER Jun 14, 2020
    that stuff works!!
  • Andrew Taylor
    Andrew Taylor Jun 14, 2020
    Yes, it is a lot better than neat bleach and it has no toxic fumes.
  • Vinesh K
    Vinesh K Jul 22, 2020
    Thank you for this information. we are from Pepetrip packers and movers company. submit a request to get a migration done.http://pepetrip.com/packers-and-movers-c...
  • Andrew Taylor
    Andrew Taylor Jul 22, 2020
    Vinesh K, you are a spamming ******! There are no Indians on this North American help site, you dipstick. Delete your comment or we will get the Indian government to come and find you.
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Jul 13, 2014 | Building Materials
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
Glass Shower Door
If you don't plan replacing the shower door, fill the holes with tile colour grout or other fillers you can buy from hardware stores. I am saying grout because if you have coloured tiles, the filled holes won't show prominently, otherwise fillers are ok.
Jul 10, 2013 | Home
How to clean mold from shower tiles
bleach. spray it on and leave it.. make sure you have good ventilation and never mix it with anything else. if the tiles have caulking around them then you will probably have to get a grout tool to remove it and then re-grout. good luck
Nov 03, 2012 | 2002 Dodge Grand Caravan
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
How do you remove wall tiles
You will need a chisel and a hammer for this. Will have to cover bath tup, shower base, anything that may chip from the fallen tile pieces. Start hammering the chisel behind the top tile, or smash the corner of a tile and try to remove it to be able to start. Be careful not to brake the plaster, this is the biggest problem when removing wall tiles. Keep hammer the chisel, and remove bit by bit all the tiles. Patch with plaster if big areas will get damaged in the wall.
Sep 14, 2010 | YouTube Videos
I'm insytalling new tile in shower should the frame of the shower doors be caulked?
Hello. Definitely yes. You want the tile, grout and caulk to be a semipermanent barrier for the water. If you do not caulk the frame, water will get in there and either leak or cause mold to form. Use a good quality silicon caulk, either clear, or white or a color that matches your grout lines. J.
Jul 28, 2010 | Home
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
Home Logo
57 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
