Old water filter won’t come out
SOURCE: ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
SOURCE: Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
SOURCE: kenmore model 6651701 arms are not moving, water
water is sprayed up a cylinder to the arms which usually spin you may be able to lift the arm off and check the oulet holes for clogs if this is the problem clean them out and purcase a bottle of dishwasher cleaner use it on wash cycle at least once a month.just place the bottle upside down in the metal utensil tray in the bottom of the dishwasher make sure there is nothing else in the machine and make sure that the water is hot by turning on the hot water tap before you start the cycle,,,Cleaner also has instructions on the label avaiable atanystore that sells your diswwasher soap
