Question about Bose Audio Players & Recorders
Spilled drink near bose wave system was plugged in not using after cleaned up all of a sudden the cd started exchanging on its own the bose clock went blank. I unplugged and dried everything just in case with blow dryer. How long should i wait to try to turn back on? Or is no hope?
Posted by Belinda Zdanowicz on
Vernon Taylor
  • Bose Master
  • 7,004 Answers
I don't know the answer and I suspect few would.
I had a friend who was a repair guy who often had calls from an office where somebody would tell him they had spilled tea or coffee or a soft drink on something that ceased to work. His first question was "did it have sugar in it?"
If the drink didn't have sugar it was worth trying to resurrect it but if the drink was sugared it would be more economic to write it off.
If something is just wet, I usually take off what covers I can to expose the innards and then dry what I can and then give it a couple of weeks...
If the unit turns out to be ruined perhaps your domestic insurance covers that sort of accident?
Posted on Jun 14, 2020
5 Related Answers
Anonymous
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
Anonymous
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Posted on Apr 10, 2008
Anonymous
  • 20 Answers
SOURCE: I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Posted on Dec 31, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Posted on Jun 12, 2009
Anonymous
  • 22 Answers
SOURCE: Bose Wave Radio AWR1 1W
I can tell you what to check if you know how to use an ohmmeter. But I warn you you could get shocked if you do not know what you are doing. The transformer has 3 windings, two are for DC voltages, and the other is 3V AC.Your meter can measure those using the AC scale. Next, check the voltage on the 3 terminal regulator IC. One leg will have 18V, the output will have 10V. Again please use CAUTION! Finally, the to-92 transistor Q1 is used as a 5V regulator. Check it (with power off and unplugged) for any shorts, especially base-emitter. If non of these ideas work, I would offer to buy your non working unit if you decide to get rid of it.
Posted on Jun 30, 2009
Six to eight years ago I purchased this system that included a cd exchange system. The cd exchange system stopped working and I threw it away last year. Now my cd played states it can not read the disc...
The Bose Wave System was very expensive, and should be at least checked with someone that can give an honest assessment. It is possible the Laser Pickup Assembly may need a good cleaning, if it works you can enjoy more time with it. If it fails then it is a matter of choice.
Jan 07, 2011 | Bose Wave music system Multi-CD Changer...
I spilled wine on my bose wave radio
What is the reason you made this post ? Do you want to know how to clean the wine or the radio no longer works ? Which model of the Wave radio is it ?
May 28, 2010 | Bose Wave Radio
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
Dec 29, 2008 | Bose Wave Radio
Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Dec 26, 2008 | Bose Wave Radio
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
Bose Wave AWRCC2 CD "not playable"
I had the same problem yesterday on my new Bose Wave Music System. I just kept on pressing reinsert everytime the CD got rejected and suddenly it started accepting CD's again.
May 06, 2008 | Bose Wave Radio II
Bose Wave Radio CD clock gaining two hours a day.
I have the opposite problem (110v radio but 220v power). Like to exchange the power supply?
Nov 13, 2006 | Bose Wave Radio
37 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
