It would be helpful to post brand and models with requests related to appliance queries.
If the fan is running and the lights are on but the compressor is not running, the overload relay may be arcing or overheating. The relay and overload is housed plugged into the side of the compressor in recent models. A multi-meter may be used to check the relay and overload. A start capacitor may also be attached to compressor. If the start capacitor is damaged, the compressor will not work. It must be examined for burns or arcing. If the start capacitor is damaged, it has to be replaced. If the relay, the overload, and the start capacitor are okay, then you need to have a technician perform other tests as dangerous live voltage tests are required. If the compressor itself is bad, replacement is not cheap.
First, you need to determine if the compressor is bad or rather a relay is bad. https://www.hunker.com/12001440/how-to-tell-if-a-refrigerator-compressor-is-bad
https://www.youtube.com/watch?v=y2GvqlZIIWI
https://www.sears.com/articles/appliances/refrigerators/how-to-fix-a-refrigerator-thats-not-running.html
