Question about Electrical Supplies
I have a EF3000iSE Generator Yamaha. I am unable to get it started.
I have cleaned the carb jets, checked the float, battery is good, have spark, etc. If I inject fuel into the carb manually it will start but won't start normally, any ideas?
Posted by John Arkossy on
Carl Rock
  • Electrical S... Master
  • 2,442 Answers
Carbureror is plugged up... likely it sat too long unused, with gas.
See exploded view of carburetor.
https://www.bikebandit.com/oem-parts/yamaha-ef3000ise/o/m19376#sch663501
Be sure both jets are clear. Remove the jets and spray carburetor cleaner into the jet seat and it should flow out the emulsion tube and the tiny holes in carb throat near where hrottle plate makes contact.
Posted on Jun 12, 2020
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,785 Answers
You have carb passages that are still clogged up. when you do get it all clean and running always use a little seafoam in your fuel. it works very well on small engined units... a few ozs in 5 gallons is plenty and stores very well also.
Posted on Jun 11, 2020
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
Yamaha ef3000ise shuts down after start up
Replace the low oil light censor, that's ur problem giving false reading
Oct 07, 2013 | Yamaha Electrical Supplies
Ef3000iseb runs for 5 minutes and then shuts down
u must clean the carburetor something stuck in there
Apr 16, 2013 | Yamaha EF3000iSE Generator
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Why does my yamaha generator ef3000ise petrol run out of the air filter when it is stopped but it will run fine otherwise
Carb float is stuck open. Take the carburator apart and clean it, blow it out with compressed air. put it back together see if that works
Sep 29, 2012 | Yamaha EF3000iSE Inverter Generator
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
