Question about LG Refrigerators
My lg fridge wont stop beeping - LG Refrigerators
Posted by reza kamalifard on
David Spradling
    Top Expert:
  • LG Master
  • 11,347 Answers
Beeping means fridge is hotter than temp set if getting cold replace thermister or temp sensor
Posted on Aug 05, 2020
Manoj Shukla
    Habit-Forming:
  • 98 Answers
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
Posted on Jun 15, 2020
I have a LG fridge freezer that wont stop beeping any help would be greatful model number..GWB227WLQA
Most new style have a warning tone that door is open.
start by manually pushing any door switches ( interior lights should go out). If light stays on you have faulty switch.
Freezer with no light a little harder, but if you have meter and are able to get switch out you can test for continuity.
Not sure of voltage to switch so remove power to fridge while removing switch.
With power removed ( unplugged) you maybe able to remove switch and connect wires together with electrical tape. Plug unit back in see if alarm is off.
Remember if not comfortable with that process call service.
Sep 22, 2016 | LG Refrigerators
My LG REFRIGRATOR MODEL GR642 ap won't stop beeping and I can't change any temp settings in the touch panel ? Please help ??
Turn off, unplug from wall, use surge protector and plug fridge back into the protector, turn power on, set operating temp etc. Cheers
Feb 23, 2015 | LG Refrigerators
I have an LG e522b. Came home to it beeping after holidays. Left it off for a week. Continues beeps when powering on. Temp cont flashes on freezer. But otherwise fridge works still. Beep stops when...
It would seem that a bad sensor somewhere is causing this malfunction. So check all the sensors including thermostat, temperature and door sensors cheers
Feb 04, 2015 | LG Refrigerators
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
BEEPING NOISE
in the back of the fridge there is a panel. Remove the cover plate. Look for the buzzer and remove it. This will cancel the annoying beeping noise.
May 01, 2009 | LG Refrigerators
My refrigerator LRSC26925 LG
Im afraid you may be having control board problems ... board can be found on top of fridge under plate where power cord enters unit .If your unit is out of warranty that board can be obtained through andrewselectronics.com or contact LGUSA.com for any customer service or warranty information. Unfortunatley that board is quite expensive. Try unplugging the fridge and replugging it to reset and press diagnostic button on the board
Mar 30, 2009 | LG LRSC26925 Side by Side Refrigerator
Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
Sep 28, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
46 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
