Question about Optics
How do I save weavers? - Optics
Posted by tanvi katyal on
  • STEVE SPAM REMOVER Jun 11, 2020
    you need to define this more. like what is a weever??
Jean DeLauche
  • 2,911 Answers
Hello, Tanvi -
1. Your question landed in the Fixya category for optics. "Optics" has to do with sight. I doubt that is the correct category for the question.
2. Please explain what "weavers" you are asking about and where (what country.) Are you referring the issue of suicides in the cloth weaving industry in India?
Note: Fixya.com receives questions from people worldwide. Those of us who volunteer to answer on Fixya are not mind readers and cannot guess what is meant by a question without more details.
3. You can add more information regarding your question by choosing Comment and typing added details.
Best wishes.
Posted on Jun 11, 2020
How much is a weaver v9 scope cross hair reticle 3x9 worth?
Use https://www.google.com and check for sale ads to see what is lists for.
https://www.gunbroker.com/All/search?Keywords=weaver%20v9
Example of starting bids at $85 and $150, so final price make be higher.
Aug 29, 2018 | Optics
I have lost the caps that cover windage∧ elevation dials on my k4 scope , can you help me out
Put "Weaver scope caps" in the search box at eBay. You should find some listed. Also, Iron Sight Inc. repairs Weaver scopes, you might try them.
Dec 19, 2014 | Weaver Hunting Gear Polar Caps Size G...
Unit does not turn,I think it needs a switch,looking for some place local for repair.Returned to weaver twice problem still exists
Jemenie!!! Apparently Weaver doesn't know what to do. Call the big boss and give a ear full.
It could be a bad switch, broken wire, bad image tube, faulty ccfl inverter, multiplier. Without some troubling shooting it, it is impossible to tell. stewbison
Feb 26, 2011 | Weaver NightView (849397) Monocular
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
How to create a template in dream weaver
Start Dream weaver and open a blank page.Open the Windows menu and select Templates.Click on the New Template button in the lower right corner, which resembles a piece of paper with the corner folded over. Type the name you want for the template.Insert the content you wish to appear on each page, including links, images, background colors and font styles.When finished, click on the File menu and choose Save As Template. Type the name of the template.
Apr 29, 2009 | Adobe Dreamweaver CS3 ( Windows ) for PC...
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
Weaver T-36 scope fails to hold zero
"Iron Sights" in Tulsa, Ok does service work and has parts for the original El Paso type Weaver scopes.
They have did an excellent job on my old Weavers.
They are slow turnaround, but excellent work.
May 21, 2008 | Weaver Riflescopes T-Series Adjustable...
Optics Logo
47 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
