Question about Pool & Spa
Where can I get the impeller rebuild kit seals for the half. Horsepower pump
Posted by Rebecca Appling on
5 Related Answers
rrwest
  • 11 Answers
SOURCE: pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Posted on Jan 03, 2009
Anonymous
  • 7 Answers
SOURCE: crosman model 200 rebuild kit for the pump
You can order a crosman rebuild kit from:
Bryan and Associates
Anderson, SC
1-864-261-6810
Posted on Feb 09, 2009
Pete
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
Anonymous
  • 5 Answers
SOURCE: rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Posted on Mar 09, 2010
thomasnee
  • 677 Answers
SOURCE: how tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Posted on Jul 22, 2010
How to rebuild a 1 1/2 HP pool pump
Have you checked all the rubber seals. I know mine would not run because the large rubber sead around the impeller housing went bad. While getting the part , I was told of a paper gasket at the motor and impeller housing, got that, the round rubber seal around the trap was cracked and sucked air as well. When I got inside the impeller was clogged with small acorn beads from the oak tree from three years of that. They were baby acorn about the size of a bb that filled the impeller holes. It could be a host of problems like mine. Best thing to do if you dont know how to do all this stuff is take it to a pool place and let them do it.
Jan 30, 2015 | Pool & Spa
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
I am rebuilding a Northstar pump. I thought I had an o-ring between the diffuser and the impeller ring when disasembling. I don't see the on the schematic however.
The impeller ring moves freely and does not use an o ring. The front of the diffuser does have one. It sounds like they gave you an extra. BTW I have found that Northstar pumps get about 4 years out of their motors. That is about half the average life. I hope you are getting longer than 4 years. If not, it may be worth changing to a different pump.
Jan 03, 2013 | Hayward Pool & Spa
I have 2 flotec cyclone pumps. Both need impellers. Where can I get them? I don't need a whole repair kit. Just the impellers.
I believe you can find it at this website.
http://www.pumpagents.com/JabscoPumps/Jabsco-Impeller-Guide.html
Good luck
RJ
Nov 10, 2011 | Flotec 1/2hp Cyclone Pump
How to remove impeller seal
Remove v-clamp from wet end.
Remove diffuser from wet-end using a flat blade screwdriver.
Remove impeller screw by turning clock-wise(this is a reverse threaded screw (some impellers dont have an impeller screw))
Remove back end of motor using a 1/4" hex driver.
Secure rear end of motor shaft by slipping a 7/16" open face wrench into rear electrical compartment
While securing the shaft, turn the impeller counter clockwise until its off.
Remove seal halfs and replace with identical seal.
Reverse to finish the install
Mar 23, 2011 | Sta Rite Tune Up Kit Dyn Glas Dyna Max...
My fridgidaire FBD1502rgs2 is LOUD. Used to be able to run it at night and now cannot if I want to sleep. Machine isn't cleaning very well and have to clean out the bottom quite a bit.
Remove the lower spray arm and take off the pump housing and upper pump section. Inspect the pump impeller for damage. I expect you will find some garbage stuck in there, perhaps clogging the pump outlets. (Also, look inside the spray arm and remove any debris.)
Next, remove the trim panel at the bottom front of the dishwasher, get out your work light, and inspect the motor housing for evidence of a leaky pump seal (e. g., dried soap from drip tracks). A damaged or worn impeller or a leaky seal indicates the need to install a pump rebuild kit (dishwasher pump parts are not often sold separately because it is presumed that these are all routine maintenance wear parts).
Jan 28, 2011 | Frigidaire FDB1502RGS Built-in Dishwasher
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
Pump seal is leaking water. I removed the screws holding the pump together. How do I remove the impellor to get at the seal?
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 03, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Is there such a thing as a rebuild kit?
There is no 'rebuild kit' for the pump. Clean filter and, depending on your mechanical skills, remove pump and cover and cleans out any debris in pump impeller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Beckett Water Gardening Garden
Pool & Spa Logo
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
