Question about Home Security
Please I need support to retrieve a password of this DVR X-7526
Posted by Baidooh Richard on
ray gallant
    Top Expert:
  • Home Security Master
  • 68,537 Answers
THEN CONTACT THE MANUFACTURER WE DO NOT SUPPORT THEM
Posted on Jun 10, 2020
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
IFORFOT ADMIN PASSWORD FOR MY "XVISION MODEL:16D" PROFESSIONAL 16 CAMERA (4 AUDIO) H264 DVR - PLEASE HELP
You need to be good to do it
http://www.xvisionconsulting.com/obiee/reset-admin-password/
Sep 28, 2015 | Home Security
How to reset admin password for Honeywell VISTA DVR
How to reset password Honeywell Black Dvr
Please send super posword
May 08, 2014 | Honeywell Vista-20pul - Commercial Alarm
I FORGET LOGIN PASSWORD OF "ZEN TECH DVR 36584 V
i have the same
ZEN TECH DVR 36584 V u can remove the battery and turn on the dvr but i cant log in i fogot the default password ....anyone rem it?
Aug 19, 2013 | Computers & Internet
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
Pls,... I forgot my 2go password. How do i retrieve it back. Am from Nigeria. Thanks kingsley
Pls I forgot my 2go password.How do I retrieve it back.am from Nigeria. Thanks Johnson
Mar 20, 2011 | Nokia Lands Phones
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
42 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
