Question about Mitsubishi Televison & Video
I have a Mitsubishi HS_U550 VHS recorder/player. The Power Button doesn't turn it on when plugged in to active outlet. No power up sound or display. Any suggestions to fix? Robin
Posted by Robin Smith on
Simon Atkinson
  • Mitsubishi Master
  • 1,691 Answers
Is yours fitted with a fuse in the wall plug? Replace that and see if that fixes the issue. Often the checking the simple stuff first saves you a lot of money.
Posted on Jun 11, 2020
  • 2 more comments
  • Robin Smith
    Robin Smith Jun 11, 2020
    Unfortunately there is no wall plug fuse. Just a plain cord. Other ideas?
  • Simon Atkinson
    Simon Atkinson Jun 11, 2020
    it’s a long time since i worked with VHS players so my advice is limited. Is it a fixed power lead or a removable one. if it’s removable try a different power lead.
    I think some VHS players were fitted with internal fuses. You might need to get a specialist VCR repairer to open the player up to check the internal fuses and circuit boards.
    You might have consider replacing the player as it could be cheaper.
  • Robin Smith
    Thanks Simon. It is a fixed power lead. If my only option is to open up the machine, I think it would cheaper to find a working one on Ebay. I thought maybe I was doing something wrong with the other buttons. Unless I hear other non-internal tech ideas, this machine to going to someone more technical than me. Thanks again.
  • Simon Atkinson
    Simon Atkinson Jun 12, 2020
    No problem, glad i could help. Try Googling for VCR sales websites. There are websites out there that sell nearly new and reconditioned machines. Tell them what you have, what’s wrong with it and they might offer a small trade in for it.
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
Anonymous
  • 944 Answers
SOURCE: Grill won't turn on when plugged in
try these guys for support or parts if you fancy trying youself; http://www.esalton.com/control/contactus It does sound like the control board is the problem, and if you can get a replacement, they are a couple of connectors and a couple of screws to fix. Hope this helps :)
Posted on Mar 27, 2007
Anonymous
SOURCE: won't power up
Have the same issue..When I shutdown or power goes out I can not power puter back up..Power LED on back of unit below cord flashes..I found if I opened up unit while plugged in and pulled main harness of of main board and slowly pluged it back in a few times LED would eventually stay on solid green and unit fires up..Have had this issue for about 1 year and really doesn't bother me anymore now that I have the trick to start...
Could be the power supply I was told but who knows..
Posted on Sep 07, 2008
Anonymous
SOURCE: Toshiba 42HP95 Plasma tv
toshiba plasma 42hp95 tv will not turn on red led lights blinking
Posted on Feb 23, 2009
chitownbob45
chitownbob45
  • 316 Answers
SOURCE: Fixing the power outlet in the Mitsubishi Spyder Eclipse
Check and replace fuse.
Posted on Oct 03, 2009
Mitsubishi HS-U775 S-VHS machine has no sound. Playback, rewind, FF, Pause functions work.
Get a VHS head cleaning tape from Walmart and try cleaning the players pickup heads.
Oct 17, 2016 | Mitsubishi HS-U775 S-VHS VCR
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
Jun 12, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
Unit will record by peressing the record button. But when programmed to record, the unit kicks on per the program, tape runs but does not record anything
Vintage VHS recorders can get quite messy. Probaly you need to take it to service. Presume it's time to convert your family tapes to DVD.
Sep 25, 2015 | Mitsubishi HS-U445 VHS VCR
How do I make the cassette door close on a Mitsubishi HS-U550?
Usually on the older VCRs the problem is caused by a slipping belt. You would have to remove the cover and check to see if the belt is worn and can not turn the drive.
Oct 05, 2014 | Televison & Video
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
I cannot remove a vhs tape from my Mitsubishi HS-U51 player. HELP! KEN
If you are handy,
1) Unplug unit from power outlet before you do anything.
2) Take the top off /remove - screws usually phillips on both sides.
3) You will probably find the tape of the VHS wrapped around or pulled out of the cassette so you could cut the tape and probably pull the VHS out of the unit.
4) This deck sounds like it will need some cleaning and attention.
Might be a good idea to take it into a qualified TV repair shop and mabe for a small fee they can clean it.
Blessings,
A/V Media Tech Guy
Nov 24, 2009 | Televison & Video
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Mitsubishi hs-u545 vhs vcr
Is timer selected? If so, you cannot "interrupt" it during this selection...accordianman
Feb 18, 2008 | Mitsubishi HS-U545 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Televison & Video Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
