Question about Frigidaire Washing Machines
I turned the power off to my frigidaire washer, it still is beeping E91
Posted by lorri on
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
Jul 14, 2016 | Frigidaire Dishwashers
Error code e 91 for frigadare affinity dryer
most likely faulty control board...........
cheers
Apr 05, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Atfb6000es1 frigidaire washer beeps ramdomly
Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATFB6000ES1, is beeping randomly. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if you are hearing your washer randomly beeping. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Machine starts beeping when not in use
Good Afternoon Eylene,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, beeping while it is not in use. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your washer, if it is still beeping while not in use, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
Apr 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Beep
Good Afternoon Amanda, thank you for allowing me to assist you!
I see that your Frigidaire washer is beeping and will not start a cycle. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. If resetting the power does not correct the issue, your washer could be experiencing a communication error with the control board or could have a wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best of luck - Z
Mar 31, 2014 | Frigidaire Washing Machines
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Error Code E91
E91 is for the control board failure and needs to be replaced. Here is the part to order. To replace the board remove the top of the unit.
Dec 05, 2012 | Frigidaire ATF6000ES Front Load Washer
E91
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Atf6000es error code E91
Hi Angelia,
E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
Sep 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
