Question about Water Water Heaters
My heater is running and compressor is turning on but the water doesn’t heat.. any suggestions?
Posted by Christine barakiva on
Sanjeev Kumar
    Habit-Forming:
    New Friend:
  • 119 Answers
Dirty filters the main reason for this. Clear the dirt.
Posted on Jun 09, 2020
1 Related Answer
Anonymous
  • 2712 Answers
SOURCE: Electric Water Heater Problem
When an electric water heater fails to heat water, either the power to the water heater has been interrupted or there is a problem with the controls or the heating elements. 1) Be sure electricity is being delivered to the appliance. Check the main switch on the water heater and the circuit breaker (or fuse) that serves the water heater. 2) Check the high-temperature cutoff in the water heater. Open the panel, and push the reset button. 3) If these steps don’t solve the problem, call an appliance repairperson.
Posted on Aug 27, 2008
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
1995 ford escort wagon heater problem1. 9 liter
probly the heater core when car is warmed up turn heat on and fell of heater hoses going in to the fire wall both should be hot if only 1 is it needs a core.
Apr 16, 2013 | Water Heaters
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 08, 2012 | Water Heaters
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
No hot water, checked ohms on both heat elements,top is 13.8 bottom is 13.4. i have 122volts to both elements and i played around with the heat adjustment on both top and bottom. over time could rusty well...
Marathon elements are specific to that water heater and can be ordered online, but generally are not at the local hardware.
Good to keep a couple spares around.
Marathon is 240Volt water heater.
Thermostats turn off one leg of the 240Volt circuit, so elements and themostats will always test for 120volts.
You removed wires off elements and tested each for continuity and tests showed elements to be good.
Test top two screws of upper thermostat and make sure you are getting 240V to the water heater.
If water heater has some hot water, then that says water heater is getting 240V, upper element is good, and remaining suspects are bad thermostats, bad lower element, or sediment build-up, or combination.
Open following link for troubleshoot run-down:
Water well.
If you have sediment build-up that reaches lower element, then water does not circulate around the element and water heater no longer heats very fast or accurately. If sediment is the problem, sooner or later the lower element will burn out.
Doesn't hurt to flush out the tank now and then, and vacuum out the sediment if that is problem.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Jul 10, 2011 | Rheem MR105245 Marathon Electric Water...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
Jan 25, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
