Question about Measuring Tools & Sensors
I am not getting outside temp.. I've changed the batteries, followinng the instructions and then the trouble shooting instructions and the online suggestions. Really miss knowing outdoor temps.
Posted by Judi Tennison on
  • Henryyetta Jones Jun 11, 2020
    It could be an issue with the temperature controller settings.
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 36,290 Answers
The big question here is WHAT IS IT???
Posted on Jun 08, 2020
My nextech wireless weather forcaster wont display out side temp. I have replaced the bats and held down the down arrow button
I dont have this unit but you might look for a reset button inside the battery compartment (or on the back, some times labeled).
Also, standard procedures are, remove batts. for a few minutes and follow the manuals instructions to start it up. Look for manual on internet. Also check for trouble shooting tips at manufactures web site.
You tested the "new" batteries, right? Long shot is leave batteries out over night to be sure unit is off. Try to find a reset button in manual or manufactures web site. Think about opening unit up with screw driver and look for reset. Did you follow instructions to select channel on both inside and outside units? My Weather Station has 3 chanels and I have to match them.
Nov 21, 2016 | Measuring Tools & Sensors
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
Unit shuts off when outside temp drops and will not come back on
Have him trouble shoot the defrost board. Also check the charge of the unit, it may be shutting off from either low pressure or high pressure.
Dec 06, 2008 | American Standard WCZ036F Air Conditioner
Crown vic trouble shooting
try changing temp sensor could be your problem
Jul 31, 2008 | 1992 Ford Crown Victoria
Measuring Tools & Sensors Logo
122 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
