If you are facing an
Arlo Camera Offline issue then worry not. This error can be resolved just by changing the settings on your camera.
There are many reasons which are why you might have been facing these issues. If you want to fix the issue, you must know the reason behind this issue. One of the main issues could be when you have not properly proceeded with the
Arlo setup.
Let's now move forward to the troubleshooting steps that will help you to resolve the issue.
Troubleshooting steps for Arlo Camera Offline:
When you are facing the offline issue is the Arlo camera, one thing is for sure that you are also going to face various other issues such as the
Arlo Login Issue.
Let us now proceed to the troubleshooting steps:
The first thing that you need to do is to check the camera connectivity. You have to make sure that you place your Arlo camera at a maximum of 300 feet from the base station and not too far.
If you see that your camera is very far away from the base station, then it might have been connecting and disconnecting as it is very far away from the base station.
You also need to make sure that the area is covered by Wi-Fi and you have a stable internet connection. Your Arlo camera might have been experiencing Wi-Fi congestion as well as going offline.
You need to make sure that Arlo base stations are online. The power LED and the Internet LED must be solid green.
You need to make sure that the camera is synced with the base station. Also, ensure that you check the last recording of the camera. If you see that the most recent video of the camera was recorded a very long time ago, then the camera might not be synced with the base station. If that's the case, then you need to resync the camera with the base station.
If you witness that your Arlo camera is offline after you have changed to the new router, or might have modified the network, then press and release the sync button on the Arlo base station of the Arlo Smart Hub.
The internet LED is going to blink for around 10 seconds and then you will see that your Arlo camera is going to come back online.
You need to disconnect the Arlo from the power source which is to unplug the power cords. You need to make sure that you take the batteries pair out and then put them back in the battery compartment after at least 10 seconds.
Then you need to plug the Arlo back to the power source and then check the status of the lights.
