Question about Electrical Supplies
When the main power supply is on generator starts up and runs for a few minutes, after that it stops for a few seconds and then starts up again? This problem cycle continues
Posted by suggie padayachee on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Electrical S... Master
  • 35,785 Answers
No name or maker of genset shown. obviously it has a shut down fault
Posted on Jun 07, 2020
How can I diagnose the problem with the indicator light flashing after supplying power for only a minute?
a problem has arisen in the converter panel /board
take it in for a proper diagnosis and repair
Apr 20, 2016 | Honda EB3000C CYCLOCONVERTER Generator -...
Kubota troubleshooting
Try bleeding the generator as some air could have entered in the system.
Mar 13, 2017 | Electrical Supplies
Perkins 20 kva diesel generator runs and stops in about 2 minutes.alternator failure is displayed on screen.
Ensure any engine control switch is set to the run position, with the load disengaged. Manually set the air shut off valve (if fitted) to the run position (see Fig. 18), Turn the key switch to the start position, which will energize the solenoid allowing the engine to crank over for a few seconds then start.
Check the instrument panel is showing normal running oil pressure, and the ammeter for charge to the engine batteries.
Allow the engine to run for five minutes checking the instruments are reading correctly. Stop the engine and check the oil and coolant levels, replenish if necessary.
https://www.dieselgeneratortech.com/generator-sets/normal-starting-procedure-of-Perkins-generator-set.html
Sep 28, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
As soon as I shut the microwave door, it starts running. I can't get it to stop unless I open the door again. When it first started giving problems I had selected the minute express feature. It started...
This sounds like a controller problem. If you are lucky, it's just a failing power supply filter capacitor (cheap and easy to replace if you are an electronic tech). Another possibility is the magnetron relay is sticking, and it's presently stuck on. That's about a $5 part from an electronics supply house. The worst case is the main controller chip - if that is a chip-on-board (circular black rubber blob in the middle of the controller board), you will have to replace the entire controller.
Dec 22, 2010 | GE JE1460 Microwave Oven
Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Jul 28, 2009 | Coleman Powermate Premium Plus 6250W...
Generator will start and run easy, then just die.
Check for loose wiring connections, especially at the run or kill switch. Generators vibrate a lot so it could be as simple as something loose.
Jun 15, 2009 | Electrical Supplies
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
It sounds like you are not producing any voltage. When you start your generator have a volt meter on the generator breaker to see if there is voltage present when the genset is running. Also, check you oil pressure switch, which is near the oil filter.
Apr 11, 2009 | Electrical Supplies
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
