1. Locate the remote wiring harness on the generator. This will be a bundle of wires with a plug on the end. 2. Connect the plug on the end of the remote wiring harness to the receptacle on the generator. 3. Connect the other end of the remote wiring harness to the remote control box. 4. Connect the black wire from the remote control box to the negative terminal on the battery. 5. Connect the red wire from
Hello dear, have you solved your problem? I am glad to help you out. We know that some malfunctions may occur that will cause the generator fail to start after using a diesel generator for a long time. What can you do when it happens?
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
Hope you can get help from this article: Why Diesel Generator Fail to Start
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
just search on You tube as Pakistan free energy Magnet motor. you will forget generators. See professor Yel free energy magent motor in delft university on Youtube.
There is no problem to use it if the load to be transferred is under 7500 W.
Even a load of 8000 W may be handled for a short time, but if the protection of the switch is adjusted at 7500 W (the respective current), it may drop after some time.
