Question about Panasonic Televison & Video
What causes my Panasonic 50 plasma tv to blink red one time on power button sometimes you can hold power button in and tv will come on and work fine sometimes it doesn’t want come on I’m thinking it’s the power supply board any help would be great?
Posted by Roger on
5 Related Answers
james klgr
james kilgore
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
Anonymous
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
vinnyq
vinnyq
  • 157 Answers
SOURCE: 6 blinking red lights on my 50 inch phillips plasma.
If you see bad capicators, just replace the ones that appear to be bad. There are many different types of capicators on the power supply and there are different part number for each one. The good thing about capicators is they almost always list the ratings on the capacitor itself.
Check the Voltage rating (V) and the Farad ratings (F, usually μF), you can replace them with any one that has the same ratings. Make sure BOTH of them match the old ratings, you can purchase at just about any electronics store that carries electrical components such as RadioShack.
Posted on Oct 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
Posted on Mar 04, 2010
Chi Chu
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
https://www.youtube.com/watch?v=awnrE3k_G2M
Mar 09, 2016 | Panasonic Viera Tc-p50gt25 50" Inch Full...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My Panasonic TH-42PZ700U 42in. TV doesn't turn on anymore. The red power light blinks 7 times. I hold down the power button until it stops blinking. When I let go of the button, the red power light stays...
Mar 04, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
