Question about Frigidaire Washing Machines
I have a Frigidaire stackable dryer that the start button seems to not work therefor my dryer won't turn on. Is there a reset button or a simple and cheap way to have this fixed
Posted by Tammy Perdue on
5 Related Answers
Anonymous
SOURCE: bought a frigidaire stackable washer
It has a stacking kit you need to purchase.
Posted on Apr 08, 2008
James Chandler
  • 686 Answers
SOURCE: irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Posted on Mar 02, 2009
Wayne Holden
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
Anonymous
  • 239 Answers
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Anonymous
SOURCE: Frigidaire stackable washer-dryer
I would check the manual.
Posted on Mar 14, 2010
I have a stackable frigadare w/dryer. Washer works great but the button to start the dryer just hums. Belt is ok.
It seems like this dryer need new dryer motor
In order to be sure ,take belt off and try to start dryer ,if dryer still humms it is motor problem for sure,
Jun 04, 2014 | Frigidaire Washing Machines
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
Is there a reset button on Frigidaire stackable washer/dryer combo. Dryer will not come on, washer works fine. thanks
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 25, 2010 | Frigidaire Washing Machines
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
My dryer (frigidaire stackable washer/dryer) just stopped working, the washer is fine, but when I start the dryer nothing happens. I set the time and push the button and NOTHING.
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Dec 09, 2009 | Frigidaire Dryers
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
We have a stackable unit and whenever we have to unplug it, the dryer will not heat. Is there a reset button?
can you describe to me alittle more in detail what your doing and is it electric heat
Jun 01, 2009 | Frigidaire Dryers
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
