Question about Radio Communications
Paring my remote to my wingman it will not pair
Posted by David Woods on
Andrew Taylor
    Top Expert:
  • Radio Commun... Master
  • 33,350 Answers
Never heard of that before, but the Internet has.
https://www.google.com/search?q=remote+to+my+wingman
Posted on Jun 03, 2020
I do not the remote to access the youtube aapp on my samsung smart tv is all paring codes the same if so what is the code. Thanks in advance
Guys - He asked for PAIRING codes, not Universal (or Zenith, anon) codes.
Pairing is done by pushing Pairing button within 1 meter of TV.
Jan 23, 2016 | Samsung Televison & Video
Having a problem pairing my iPhone 6 to my Tx-sr333 receiver. Iphone just grinds and can't find Bluetooth.
Hi Don,
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
Mar 09, 2015 | Onkyo Audio Players & Recorders
Paring bluetooth
make sure that your jabra is in pairing mode then go to the bluetooth menu of your pc. select add device and wait until your computer finds the headset
May 11, 2013 | Radio Communications
How to connect to phone
Pairing the Headset
*You are required to pair the headset with your mobile phone or other device before using it.
1. Ensure the headset is off, then press down the P2 button until the pairing mode (both Blue & Red-LED's are flashing
alternately), then release. This will take about 6 seconds.
2. Initiate pairing process of your mobile phone. Refer to the manual of the mobile phone for the direction. You will see a new
item "BT headset" added in your Bluetooth device list after the searching process.
3. You will be asked to enter a pin code to complete the pairing. Enter 1234 and confirm. (Note: the 1234 is a default pin code
pre-stored in the Headset) The red indication will turn off and the blue indicator will flash slowly after the paring is completed
successfully.
4. Once the pairing is complete, the Red LED will turn off and the Blue LED will begin blinking, (indicating standby mode). If it is
not finished paring within 2 minutes, the headset will go into standby mode, and pairing is unavailable. You will need to restart
and repeat steps 1-3.
MANUAL HERE:
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Oct 04, 2012 | foneGEAR (00976) Wireless Headset
Pairing instructions and code for pairing
paring what? please complete information thanks ^_^
Jun 03, 2010 | Anycom HCC-250 Bluetooth Headset
Paring number jabra bt135 0000 won't work any info
To pair you must first switch it off (press and hold for 5 sec) then press the button for another 5 seconds till the button backlight stays on continuously. The pairing code is 0000.
Jan 26, 2010 | LG KG800 Cellular Phone
Paring gnx bluetooth headphone
Press power (small triangle) and vol up (small thin button on the side near the led light) buttons together for 4 seconds until it goes red/blue for pairing (up to a min). Passcode is 0000.
Sep 13, 2009 | Samsung SBH170 Stereo Bluetooth Headset...
Cannot pair
if you can pair this device go to paring mode by pressing the answer/end key and the volume up( +) key at the same time over 5 seconds until the blue indicator light lights up.
after do this try to paring again.
Jul 20, 2009 | Nokia HS-36W Wireless Headset
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Paring
you simply pair two phones together. did it work? let me know.
May 14, 2008 | LG VX8300 Cellular Phone
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
