Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before doing anything, try a Hard Reset to this set, and then check. To do a hard reset, just unplug the set from AC mains wall socket, and reconnect it after some time, say after an hour or so. If you do it overnight is better.
If it do not help, contact the authorized service center. It will be the best.
SOURCE: DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
SOURCE: Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
SOURCE: PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
