Question about Sport & Outdoor - Others
I have a WMT 6000 tent I need poles,my tent is in excellent condition.
Posted by Ruben on
ray gallant
    Top Expert:
  • Sport & Outd... Master
  • 68,557 Answers
WE DON'T SEARCH FOR TENT POLES HERE
Posted on Jun 01, 2020
Need the manual for an Ozark Trail WMT-1390 cabin tent, please.
Try Googling (Ozark Trail)(WMT-1390)(manual) without pares OR contact the manufacturer/distributor.
May 08, 2018 | Sport & Outdoor - Others
Need 1 replacement pole for a ridgeway kelty ranier model 890110 part # 94 2014
take your pick
Kelty ' Camping, Hiking & Backpacking Gear For Any Outdoor Adventure
https://kelty.com/
  1. Cached
Kelty builds quality tents, sleeping bags, backpacks & camping gear for any outdoor adventure from the backyard camper to the experienced backcountry hiker.
Replacement Tent Poles ' eBay
www.ebay.com/bhp/replacement-tent-poles
  1. Cached
  2. Similar
Find great deals on eBay for Replacement Tent Poles in Tent and Canopy Accessories. Shop with ... Fibreglass Replacement Pole Kit 7 Sections Camping Tent Equipment 60cm x 7.9MM, true ... (E.g. you brought wrong model or wrong color).
Shop Kelty Tent Replacement Parts & Discover Community Reviews ...
https://www.massdrop.com/kelty-tent-replacement-parts/s
  1. Cached
Shop popular kelty tent replacement parts chosen by Massdrop communities. Join Massdrop to discover the latest details and related kelty tent replacement ...
Tent Poles, Tent Replacement Poles, Tent Stakes - Cabela's
www.cabelas.com/category/Tent-Repair-Replacement-Parts/106666380.uts
  1. Cached
  2. Similar
Carry any extra tent replacement poles and stakes in Cabela's gear and duffel bags for a convenient ... Alaskan Guide® Model Replacement Fly Vestibule Pole. replacement pole for ridgeway kelty ranier model 890110 Google Search
Jun 08, 2017 | Kelty Baby Gear
Instuctions for 13×9 cabin tent sleeps 6 wmt-1390 (not instant)
OWNER'S MANUAL WARNING: KEEP ALL FLAME AND HEAT
SOURCES AWAY FROM THIS TENT FABRIC.
This tent meets the flammability require-
ments of CPAI-84. The fabric may burn if left
in continuous contact with any flame source.
The application of any foreign substance to
the tent fabric may render the flame-resis-
tant properties ineffective.
DO NOT...
1. Do not pitch tent near an open flame.
2. Do not leave campfires unattended.
3. Do not allow CHILDREN or ADULTS
to use lighted candles, matches or
other flame sources in or near tents.
4. Do not use heating, lighting or
cooking equipment with open
flames in or near tents.
5. Do not use fuel burning/oxygen
consuming devices (i.e. heaters,
lanterns, or other flame sources)
inside your tent at any time.
6. Do not use other than recommended
water repellent compounds on your
tent.(See:"Seal the Seams")
7. Do not spray the tent with insecticide.
8. EXTREME CAUTION: Never use any
fuel burning/oxygen consuming
device, or any device that produces
fumes (including stoves, lanterns,
candles, hibachis, or heaters) in or
around your tent. Inhalation of fumes
may result in carbon monoxide
poisoning, injury and/or *****.
DO...
1. Always extinguish campfire before
leaving area.
2. Exercise care when using electricity
and lighting in and near tents.
3. Disassemble and store tent properly
after camping to ensure the tent's
longevity.
4. Always use a hammer/mallet when
driving stakes into the ground. CARE This recreational item is not intended for
use as a permanent structure, as fabric
will quickly degrade if exposed to UV
light. No (sun shelter, screenhouse, tent)
can withstand prolonged exposure to
sunlight. UV damage is not covered under
the limited 90 day warranty.
Structural Integrity
Although our tents and screenhouses are
constructed to rigid specifications, periods
of wind or rain soaking the ground may
loosen the stakes and cause the uprights to
sink into the ground. This will weaken the
rigidity of the overall structure. Water pock-
ets may also form in the roof if the unit is
not assembled taut, the weight of which
may cause broken frames and torn fabric
Storage
Tents/screenhouses must never be rolled
up or packed while damp, as mildew will
form within a few days. Allow tent to dry
completely before rolling and storing.
REPLACEMENT PARTS Always mention the Model number in all correspondence regarding your tent and when ordering
replacement parts. ASSEMBLY INSTRUCTIONS Lay Out the Screenhouse and Poles
Select a smooth, level site and spread out your
screenhouse.
Sort the poles by number and connect the
sections together. See diagrams below for
numbering
tep 2 - Install the Poles
Insert the ends of each of the three roof poles
into the 3-way hubs
Insert the four side roof poles into the 3-way
hubs. See Diagram 2 Insert the leg poles into the hubs to raise the
screenhouse frame. Make sure that the pole
end with the holes in the sides (
down. See Diagram 3
Secure the Screenhouse
Drape the screenhouse body over the frames.
Hook the S-Hooks
located at the bottom of the leg poles.
L
Wrap the velcro tape
screenhouse, around the poles to secure them.
When the screenhouse is in its proper location,
stake it down by driving stakes through the
four D-rings
Step 4 - Install the Guy Lines
Tie the loose end of a guy line through D-ring
Repeat for the other three guy lines.
1B
Make a loop at the end of the guy line with the
L
slider. Stake the looped end of the line out
about 3' from the base of the pole. Adjust the
slider until the line is taut
C
Sep 28, 2016 | Sport & Outdoor - Others
#WMT-5100 PENTAGON 3 DOME CONNECTION TENT MANUAL
Need instructions for the WMT-5100 3 dome tent.
Apr 08, 2012 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    Lost ozark trail wmt 1390 tent manual
    I have a copy of the Ozark Trail wmt-1390 tent manual. It is in pdf format. Just email me for a copy.
    Mar 26, 2011 | Sport & Outdoor - Others
    Sport & Outdoor - Others Logo
    35 people viewed this question
    Top Sport & Outdoor - Others Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
