SOURCE: Beko 727W washing machine. Washing still wringing wet after wash.
If it is still under warranty, by all means keep calling the company and complaining until they fix it. Trying to fix it yourself will risk invalidating the warranty altogether.
My initial guess is that there is something blocking or slowing down the drain pump, which is preventing spin cycle from working properly, but with a front loader that is only one of quite a few possibilities.
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
SOURCE: My mother accidentally pulled the
Switch the machine off at the panel and at the wall plug, this will reset the main logic board as you've interrupted the cycle and confused the electronic calculations in simple understandable terms.Then close the door and make sure that it is firmly closed(won't open on it's own due to a damaged lock from forcing) if it remains closed and firm then the locking mechanism is not broken. So switch on the wall plug first then the main on off switch on the panel if there is one.There should be life. If there is you are lucky there is no damage, if not then you will have to replace the door lock switch.
