Question about Vehicle Parts & Accessories
Need ac/dc charging adapter for my Vector - Vehicle Parts & Accessories
Posted by southerng835 on
Attique-ur-Rehman
    Top Expert:
  • 2,677 Answers
You can purchase from:
https://www.amazon.com/Adapter-Charger
Posted on May 29, 2020
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: durabrand ac/dc adapter model TAD-10
you can buy an aftermarket brand that is the same as the Durbrand ac/cd adapter model Tad-10 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Posted on Dec 18, 2008
Anonymous
  • 30 Answers
SOURCE: Recharging the Vector Start-It compact elite Jump Starter 12 volt
yeah from what im to understand... you charge it overnight, and yes another way to use it (and possibly better way) is connecting to the battery directly..... it should work on your van fine i think, its worth a shot, hope this helps :)
Posted on Mar 11, 2009
Anonymous
SOURCE: lost the 12-volt DC charging cord for my vector jump starter
google the name and model #. The home website should come up in search. Go to site, and look in support, or replacement parts.
Posted on Aug 23, 2009
Anonymous
  • 3 Answers
SOURCE: I need to replace the ac adapter for my vector
http://www.stylefeeder.com/i/6sr4398f/Black-Amp-Decker-5140045-42-Replacement-A-C-Charger
Posted on Dec 13, 2009
Anonymous
  • 4 Answers
SOURCE: I need a vector jump starter ac adapter. Lost
Radio Shack
Posted on Jul 10, 2010
I need to buy wall charger for my power on board mod numer veco12p0b
For replacement parts (charging adapters, etc.), contact Technical Support, toll free
at (866) 584-5504. Here's the owners manuel. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC012POB.pdf
Good luck.
Nov 04, 2010 | JUMP START SYSTEM
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
Can't find chargers for my 1M cp vector vec127by spot. What are the charge rates for a 120v ac charger and the dc car charger?
10-12 hours for 120v AC charger, I do not recommend using a DC car charger to charge the battery. You can purchase a replacement AC charger from Black and Decker, they service Vector products. here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jan 29, 2010 | Camping, Backpacking & Hiking
Vector VEC438 AM/FM/Weather Radio my AC adapter
I have one of these too. Here is the information, in case you don't still have the adapter.
Ktec
Model KA12D090050034U
Input 120V AC 60Hz 95mA
Output 9V DC 500 mA
The inner part of the plug is the positive side.
Try googling the model number above. I did and found several sources. If you still have the adapter and only the power supply itself is bad (but the plug is still good), you may be able to splice on another 9 volt DC adapter, as long as the power output is 500 mA or greater. If you go this route, make sure to check the polarity before plugging it into the radio.
May 06, 2009 | Vector VEC438 AM/FM/Weather Radio
Instructions on AC Chargeing Vector Jump Start 12 volt
When charging the jump starter , should the switch be on or off .
Mar 30, 2009 | JUMP START SYSTEM
Mar 11, 2009 | Vector VEC010S Jump Start System 300 Amp...
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
