SOURCE: diplomat dishwasher ADP 8332
If the pipes are cracked you may be able to get new ones from a local appliance parts dealer. If the fittings are the problem Check with the formentioned.
SOURCE: Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Fulvio
SOURCE: I need help with my
Hi, you see when any unit or set is left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, not to mention, any other sort of corrosion, or perhaps flat cells in a unit, inductors etc. So as said, this makes a unit more or less unrepairable, or at least in need of a thorough going over to find out the problems..
Also backup batteries go flat and this too will cause units to not be able to start up as thier "Clocks" are wrong as the battery is flat, as it hasn't been charging.
