If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
SOURCE: SAMSUNG HM100JC
i am assuming the drive E:/ refers to your dvd or cd drive, if so it may be faulty and need replacing, but the only thing to try and resolve it other than having to buy a new one is: control panel>device manager(or system icon)>hardware tab, look down list for Cd/DVD drives, click + sign right click on drive and select uninstal. Restart pc and it will install itself, see if it works and shows in my computer, if not the drive needs to be replaced.
SOURCE: kolin color tv,degausing problem.
Degaussing coils do not work on LCD or Plasma TVs, Cathode Ray Tubes only. There should be no (not any type) demagnetizing circuitry on that type of set, so I have no idea what you replaced/adjusted. I believe one of two things to be the problem. Either the LCD screen itself is bad (possibly it has been struck with something and that has broken electrical connections that cannot be repaired) so replacing the LCD panel may prove to the the fix. However, the circuitry that drives the LCD panel could be at fault, improperly driving an otherwise good LCD screen. That is a tough call. I would carefully inspect the screen up close looking for tiny cracks in the glass. This could be a pricey repair either way. Good luck on that one. Perhaps you should include some more history of the set. Did it fall or get knocked over, was recently moved, got wet... anything would be helpful. I know that children of a certain age are known to go up to a set and slap the screen. A friend has a rear projection Pioneer with that type of damage.
SOURCE: color on projection tv 9P6040-C104
HOW CAN I REPLACE THE FLUID IN THE CRT'S WHERE DO I GET THIS FLUID
SOURCE: my printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
SOURCE: TROUBLE SHOOTING SHARP COPIER CODE F 5
i have problem in Sharp AR 200,and i dont know haw to fix,error code F5
